587,349 active members*
3,066 visitors online*
Results 1 to 5 of 5
    Jun 2014
    777
    Urgent help needed. TIA
    Hi There.
    Okay, Machine has been running without electrical fault for nearly two years. I'm now getting an odd issue where the y axis (2 x slaved nema23 planetary boxes run from x 2 dsp mosfet drivers) stopped and would judder tying to go on but not a stall whine, Both motors. and I then find the connectors for my z motor are hot to the point where the red insulation has gone black. The 3 dsp drivers share a single 48v psu. X is on its on toroidal transformer. The z runs fine and the motor is warm but not overly hot. Why are the automotive connectors overheating? They are not anywhere near any other cables or any grounded parts immediately around the connector. (Hanging in mid air currently). And what does this have to do with my two slaved y drivers.
    Thanks for reading, hope you can shed some light on this. Is it possible that the z single dsp driver is drawing current away from two slaved y drivers? TIA
    Jun 2014
    777
    Re: Urgent help needed. TIA
    Update.. Ive let connectors cool. and when machine switched on and the connectors and wires around connectors get hot immediately, (bullet type automotive ones)
    Jun 2014
    777
    Further update. air cutting same sheet that has shown issues with the y and monitoring voltage across the 3 x dsp drives @ 47.7 - 47.8v constant. Changed connectors for new ones now they are staying cool which is good
    not seen the issue again in the y yet So is there any scenario that those z connectors could have caused the y to have issues? Tia
    Jun 2014
    777
    No help here then
    Mar 2007
    2083
    Hi
    just found your post today
    what's motor current set to ?
    I expect your problem will be due to the connectors being make down to a price and / or you had a poor crimped joint
    once you pass a high current through a joint with an excessive resistance the heat generated will oxidise and soften the contacts
    resulting in even more damaging heat
    John
    PS
    GeckoDrive.com supply four high current 9 pin connectors for the same reason
    as many D-type connectors found online are only suitable for use on low current signal cables
    and not the possible 3.5A from a G540 stepper motor drive
  1. Urgent G76 help needed please
    By 30tooo in forum Fanuc
    Last Post: 06-19-2016, 07:55 AM
  2. EMERGENCY - NEED HELP SOURCING UK SUPPLIER - URGENT URGENT URGENT
    By ApexLaser in forum Want To Buy...Need help!
    Last Post: 07-19-2014, 04:37 PM
  3. HELP NEEDED URGENT
    By PeterJames in forum Machines running Mach Software
    Last Post: 01-19-2013, 04:32 PM
  4. hx40a urgent help needed
    By shellglen69 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-05-2011, 12:58 PM
  5. Urgent Help Needed!
    By tmole in forum Bridgeport / Hardinge Mills
    Last Post: 02-23-2007, 02:04 PM
