587,420 active members*
3,315 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Question on spoilboard attachement- Question
Results 1 to 13 of 13
    Sep 2007
    140
    Never having done this before just curious if anyone would care to share their method for doing the spoil board attachment? I'm thinking 1-2 pieces of 3/4 mdf? How'd you do yours?
    Jun 2013
    88
    Re: Question on spoilboard attachement- Question
    Hi bonesbr549, There are a number of good options depending on your machine and the kind of work you do.
    3/4 MDF using M8-16 button head fasteners in .5" deep pockets is probably one of the more common setups (can get extra M8-16 fasteners w/roll-in t-nuts from our store --> M8 Roll in T Nut | CNCRouterParts)
    Here is a link to our reference spoilboard project --> Benchtop PRO CNC Spoilboard by CNCRouterParts - Thingiverse
    This is presented here as a Benchtop PRO 2'x2' project, however the Fusion and Vectric project files are provided and can be adapted to the size of your machine (if you want to use them, take a look at the included how-to videos).
    Making a Spoilboard for the Benchtop PRO Part I - Using Vectric Cut2D, VCarve, or Aspire
    Making a Spoilboard for the Benchtop PRO - Autodesk Fusion 360 Design Overview and G-Code Creation
    Making a Spoilboard for the Benchtop PRO Part II - CNC Machining, Mounting, and Surfacing
    I'm hoping to see other replies, we always like hearing about what others are doing!
    -Nathan
    Sep 2007
    140
    Thanks, a picture is worth a thousand words. I'm doing a 4x8 so lets see what others are doing.
    If I may suggest nylon screws instead of steel.
    And here's why.
    The bit cut right through the nylon screw.Mistake was caused by not resetting Z axis after bit change.
    Feb 2009
    192
    Quote Originally Posted by R-Carpenter View Post
    And here's why.
    OOPS-Hey we all have done this, brass is good too. I only use brass to hold my work to the spoil board and it's saved many cutters.
    Jan 2013
    7
    I don't have pics but...
    We have a 4x8 kit built CNC from Build Your CNC (??) at our MakerSpace [URL="http://www.slomakerspace.com"] It holds a 49"x97" sheet of mdf. I used a biscuit cutter to cut slots in the edges of the mdf about every 10" then inserted 2" fender washers in the slots and screwed the washers down to the main table.
    Screws are totally out of the way of the bit.
    Apr 2015
    82
    i don't think i have pictures of building my spoil board, i made mine by drilling a 2 inch grid pattern and putting t-nuts in from the bottom. i attached it using a very similar method the video.
    i thought that i would use hold downs with bolts going into the t-nuts, but 90% of my parts are screwed down the the sacrificial board on top of the spoil board now.
    Jan 2015
    35
    .75" MDF held down with m6 button heads and roll in connectors. The planks are bolted through the base board and help hold the base down.
    Jan 2017
    1
    For some reason it's not allowing me to open the files in fusion? Can you help me out there?
    Jan 2013
    31
    Quote Originally Posted by dajones9 View Post
    Make sure you are using the <file_name>.f3d file. Then at the top using the file menu (between the data panel and save button) select 'new design from file'.
    Jun 2013
    88
    In case folks haven't seen it, we recently updated our reference spoilboard project for large format machines (still configurable for custom sizes from 2' x 2' benchtop machines to 5' x 10' and beyond).
    PRO Series Spoilboard | CNCRouterParts
    There are three sketches/layers - crossmember mounting pocket and slots, as well as optional geometry for bench dog/threaded wood inserts, and clamping slots.
    -Nathan
    Feb 2005
    829
    I actually drilled and tapped the aluminum extursions directly. Making it super easy to screw down the base board. I used 18mm Baltic burch for the base, then glued 3/4 MDF to the top for the spoil board. I am about 1/3 of the way thru the spoil board after 2 years.
    Aug 2016
    122
    I have a Standard 2448 machine. Nothing fancy here...I used a 2x4 pice of MDF. I clamped it in place over another piece of MDF to drill the holes and countersinks. I used the nuts and bolts from CNCRP. I then added a piece above that one to destroy. It needs surfacing now.
    Oh, I used a couple of strips of 1/2 MDF to act as dust shields on each side of the 2x4 sheet. They are floating. Just wanted to keep dust from underneath the table.
    Tony
  1. Spoilboard question..
    By SixOfOne in forum DIY CNC Router Table Machines
    Last Post: 02-10-2016, 09:26 PM
  2. Lines while engraving with laser & rotary attachement
    By blh8426 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-10-2016, 04:27 AM
  3. Pictures of Micro Mill with Power Feed Attachement
    By Dennis Bohlke in forum Taig Mills / Lathes
    Last Post: 09-09-2014, 09:04 PM
  4. Replies: 9
    Last Post: 08-01-2013, 10:25 PM
