587,935 active members*
4,354 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > CNC Bridgeport series 1 boss convert to mach 3
Results 1 to 11 of 11
    Sep 2016
    2
    New to the forum. While looking for a manual bridgeport I came across a cnc which I feel is a decent deal on a machine. Around $1000 for a Bridgeport series 1 cnc a half hour from home. I have been reading everything I can find for the last two weeks on forums and can't seem to find the info I need to decide on this purchase. I just want a 3 axis cnc mill in my shop. Not worried about tool changers, tapping, 4th axis ect. This is for my personal hobby-offroading, drag racing- shop with intentions of some small amount production fab work eventually. Affordable and not too too much of a project is my main concerns. I am leaning toward mach3 since it seems to be the most popular with lots of support forums if I have issues. I don't want to just go buy a retrofit kit if I can DIY this and save tons of money plus learn more along the way.
    The machine has motors on x, y, and z axis'. It has a tape reader on the side of it and a control panel that looks like some sort of one line at a time g code. Machine appears to be in good shape and is still hooked up. Number on the knee is j199396c. Number on the spindle motor 2j-69631c. Variable speed spindle with high and low. Not sure what style tool holder it is. Ways look to be in good condition.
    What I am having trouble finding:
    How to tell which BOSS system it is? If one would be better/worse?
    What specifically do I need parts wise to convert this to Mach3 controller?
    If I were to keep the axis motors that it has how or would I be limited in any ways? Could I keep use those for now and upgrade later?
    Any info will be greatly appreciated!
    May 2006
    168
    Re: CNC Bridgeport series 1 boss convert to mach 3
    I love mine. I use LinuxCNC but the changeover is pretty. Remove all the electronics except for the stepper motors then add modern stepper drivers and your favorite CNC software.. My mill is at http://www.cnczone.com/forums/bridge...22953-cnc.html
    May 2014
    170
    Make sure the ways are solid. CNC machines do not like sloppy
    Sep 2016
    2
    In the last day or two I've learned that I will need a driver for each axis motor.
    The breakout board and motion controller are just different names for the same part.
    I still havent found anything else to determine wich BOSS system this machine is or what the differences are in BOSS 1-10.. or if it makes any difference since I want to upgrade anyway
    Rlwoodjr I have came across your post in my searches. I didnt even notice the links at bottom of the post for pics. I am just used to them loading on their own. Yours looks good. I like the clean small box for the electronics.
    The machine I'm looking at has stepper motors for sure.
    May 2006
    168
    Thanks, you do not need a lot of space for the power supply and stepper drivers.
    Mar 2012
    192
    I did mine much like rlwoodjr. Mine's a BOSS 3 (a knuckle-head) and it has the steppers with large cast fins. I use the same Gecko drivers and I re-used the smaller box from the back over to the side so I could install the VFD and PC with the rest of the control system.
    Do make sure the ways and ballscrews are in good condition. Mine had the Z-axis quill over-extended and some of the balls came out. I discovered that during a complete tear-down and it took months to sort out (I have a few threads here about various aspects of my build). Beware, the software side may not be cheap or easy.
    Jan 2005
    15362
    Quote Originally Posted by scottystephenss View Post
    No the Breakout Board and the motion controller are two different parts of your system
    A basic guide to tell you what you have is early Boss machines up to Boss 5 have a 1:1 Timing Pulley Ratio after the Boss 5 they had a 2:1 ratio, this is easy to check on the Y axes
    Mactec54
    Nov 2016
    42
    Quote Originally Posted by rlwoodjr View Post
    What are you running for drives and power supply? What current and voltages are you running
    Mar 2012
    192
    I am using Keiling torroidal power supply, 72VDC 20 amps runs Gecko G203V drivers. Motors wired parallel.
    Nov 2016
    42
    Quote Originally Posted by 1875 View Post
    What brand motors? I'm running boss t2 as power supply. Lead shine dm860 drives. What are you using for software?
    Mar 2012
    192
    I kept the original motors - forgot which ones. I've used both Mach3 and LinuxCNC. Still playing with the software part.
  1. Bridgeport Series 1 cnc Boss 5
    By pyroboby in forum Bridgeport / Hardinge Mills
    Last Post: 09-01-2012, 11:44 PM
  2. Bridgeport Series II Std with Centronics convert to steppers
    By caden in forum Bridgeport / Hardinge Mills
    Last Post: 02-01-2011, 09:25 AM
  3. Easiest way to convert Bridgeport Series II Interact 2 to EMC?
    By ichudov in forum Open Source Controller Boards
    Last Post: 03-08-2010, 11:02 PM
  4. To convert or not, bport series 1 cnc Boss 5
    By Mcgyver in forum Bridgeport / Hardinge Mills
    Last Post: 08-15-2009, 06:40 AM
  5. Bridgeport Series I Boss 4
    By millwrightguy in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2007, 02:07 AM
