587,523 active members*
3,625 visitors online*
Results 1 to 5 of 5
    vfsi Guest
    Help with Siemens Macro Reading and Writing to a file
    I have a macro that has me stumped. On a Siemens 810D, I can write to a file but I cannot read the data back in. I don't get an error from the read command. Error Boolean = 0 , I just get no data. VALSTR[1] = VALSTR[2] = blank (no data).
    Here is a program snippet:
    N7 DEF INT FILE_ERROR ; READ WRITE ERROR RETURN
    N8 DEF STRING[255] VALSTR[2] ;NUMBER AS A STRING
    N10 DEF REAL SLNUM ; NUMBER
    N12 DEF BOOL VALIS ;TEST RETURN OF ISNUMBER
    N14
    N20 READ(FILE_ERROR, "/_N_SPF_DIR/_N_TESTFILE_SPF", 0, 1, VALSTR)
    N22 IF FILE_ERROR <>0
    N24 MSG(<<FILE_ERROR<<" TESTFILE FILE NOT FOUND, CORRECT AND PRESS CYCLE START")
    N26 M00
    N30 ENDIF
    N32
    N34 VALIS = ISNUMBER (VALSTR[1])
    N36 IF VALIS == FALSE
    N38 MSG("FILE DATA IS NOT A NUMBER," <<VALSTR[1]<< ", CORRECT AND PRESS CYCLE START")
    N40 M00
    N44 ENDIF
    N92 SLNUM = SLNUM + 1
    N94
    N96 VALSTR[1] = <<SLNUM
    N104 WRITE(FILE_ERROR, "/_N_SPF_DIR/_N_TESTFILE_SPF", VALSTR[1])
    N106 IF FILE_ERROR <>0
    N108 MSG(<<FILE_ERROR<< " TESTFILE FILE NOT WRITTEN, CORRECT AND PRESS CYCLE START")
    N110 M00
    N114 ENDIF
    If I change "VALSTR" to VALSTR[1] in the read command I get a variable error. WHY?
    Also my write file appends but does not OVER WRITE the existing data. WHY? The Programming Guide 11/2002 Edition, 1.17 WRITE Write file (SW 4.3 and higher) says: "If a file with the same name exists on the hard disk, it is overwritten after the file is closed (in the NC)."
    Any guidance would be treasured.
    May 2013
    37
    Re: Help with Siemens Macro Reading and Writing to a file
    Because you definiens >> VALSTR[2] but when you write varitable name you must remember abaut syntax:
    VALSTR[0] - 1
    VALSTR[1] - 2
    so when you read file READ(FILE_ERROR, FILE, 0, 1, VALSTR) you write data to VALSTR[0] not for VALSTR[1]
    fix program:
    PROC _N_RW_TEST_MPF SAVE
    N10 DEF INT FILE_ERROR ; READ WRITE ERROR RETURN
    N15 DEF STRING[255] VALSTR[2] ;2 LEVEL TABLE STRING
    N20 DEF STRING[32] FILE
    N25 FILE = "/_N_SPF_DIR/_N_TEST1_SPF"
    N30 READ(FILE_ERROR, FILE, 0, 1, VALSTR)
    N35 IF FILE_ERROR <> 0
    N40 MSG(<<FILE_ERROR<<" TESTFILE FILE NOT FOUND, CORRECT AND PRESS CYCLE START")
    N45 M00
    N50 GOTOF _END
    N55 ENDIF
    N60 IF NOT ISNUMBER(VALSTR[0])
    N65 MSG("FILE DATA IS NOT A NUMBER," <<VALSTR[0]<< ", CORRECT AND PRESS CYCLE START")
    N70 M00
    N75 GOTOF _END
    N80 ENDIF
    N85 VALSTR[0] = <<(NUMBER(VALSTR[0])+1)
    N90 WRITE(FILE_ERROR, FILE, VALSTR[0])
    N95 IF FILE_ERROR <> 0
    N100 MSG(<<FILE_ERROR<< " TESTFILE FILE NOT WRITTEN, CORRECT AND PRESS CYCLE START")
    N105 M00
    N110 GOTOF _END
    N115 ELSE
    N120 MSG("TESTFILE FILE WRITTEN SUCCESSFUL, TEXT FILE: "<<VALSTR[0])
    N125 G94 G4 F5 ;IN 1ST LINE AM USING COMMAND SAVE BECAUSE HERE CHANGE GCODE G94/G95
    N130 ENDIF
    N135 _END:
    N140 MSG()
    N145 M30
    vfsi Guest
    Thanks Partur. It works as needed. That was the missing information. Makes sense, it is just us humans that start counting at "1".
    On another note:
    What variable register would I use to store this VALSTR value that would not reset when the controller is powered down or reset? It would be further from inquisitive eyes and fingers? Again I have read the manual but do not understand exactly how to define the register and which register would be "safe" to use so I don't write over machine data.
    May 2013
    37
    In the variable -> GUD (global user data) you have 100 string variable.
    _TXT[0]
    _TXT[1]
    _TXT[98]
    _TXT[99]
    You can using this variable to store text string when machine is off.
    macro start:
    VALSTR = _TXT[0]
    macro end:
    _TXT[0] = VALSTR
    m30
    or working only on _TXT[*] string variable without VALSTR.
    enjoy!
    vfsi Guest
    Partur,
    Thanks for the quick reply.
    It looks easier than I thought. Knowing about the GUD registers will open up a whole list of possibilities. I wonder why the Siemens documents don't do a better job of explaining the subject matter. I will let you know how it works out.
    vfsi
