587,920 active members*
3,476 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mesa vs Ethernet Smooth stepper Vs C11/C13 Board
Results 1 to 7 of 7
    Mar 2016
    19
    I was wondering if someone would be able to tell me the pros/cons of each i will be using this on a G0602 converion (and depending on the benefit i may swap out my g0704 C13 i think board) i am indifferent on running Mach3, LinuxCNC or Pathpilot thank you
    the mill will be running either a 3 phase baldor, or a 1.8kW ac cervo,
    the lathe will be running a 3 phase 1.5 hp motor
    i cannot chose between the mesa card and the ethernetsmoothstepper (warp9),
    also how do the digital drivers from Stepper Motor |CNC Router | Laser Machine | 3D Printers For Sale Stepper Motor | Stepper Motor Driver | CNC Router | Laser Machine | 3D Printers For Sale compare to the geckodrive ?
    Sep 2016
    46
    Re: Mesa vs Ethernet Smooth stepper Vs C11/C13 Board
    I would advise you to do your own research on these topics, there's a ton of information already out there that can help you that is available with a simple search.
    Mar 2016
    19
    Quote Originally Posted by DubMFG View Post
    thanks, i was hoping for "real world" experience from people, from my research i havent been able to make up my mind between the two.
    Sep 2009
    1856
    Ess is mach 3 or 4, mesa is linuxcnc/pp 2 different systems.
    just to be a pain look at pokey's 57cnc what is mach3 or 4
    The gecko drivers are very robust I have a G540 7 years old and 6 G213v 5 years old never missed a beat. I know some who has 1 of the first G540 ever made it still works you can use these with mach3 or 4 linuxcnc/pp
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    35538
    Do you want to run Windows, or Linux?
    Another Windows option is UCCNC with one of their motion controllers, which is arguably better than Mach3.
    CNC Drive's motion controllers also work with Mach3, and soon with Mach4. And imo, their Mach plugin support is much better than Warp 9's.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2016
    19
    thanks for the reply guys, i think i read it wrong where i thought that the ethernet smoothstepper works with linux cnc.
    i was also wondering if the cnc lathe part of mach3 actuall works now, i got the impression that it wasnt that good to use, thats why i was leaning towards using linux cnc, that way i would only need to "learn" one program for both my mill and lathe.
    currently my mill uses Mach3, but im indifferent to learning new things
    35538
    Mach3 development stopped about 5 years ago. Yes, it has issues, but people do use it.
    Gerry
  1. Ethernet Smooth stepper, C32 board MPG4 Pendant, New having trouble setting up.
    By ballistic42 in forum SmoothStepper Motion Control
    Last Post: 12-31-2020, 06:24 PM
  2. G540 with an Ethernet Smooth Stepper
    By dmauch in forum Gecko Drives
    Last Post: 04-04-2015, 06:21 PM
  3. ethernet smooth stepper
    By daniellyall in forum Mach Software (ArtSoft software)
    Last Post: 08-08-2013, 07:40 PM
  4. Smooth Stepper Ethernet Board - Mach3
    By mrpackethead in forum X3/SX3/G0619/G0463
    Last Post: 05-09-2013, 02:04 PM
  5. Replies: 1
    Last Post: 10-05-2012, 12:24 PM
