587,128 active members*
3,255 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > stepper motor as main spindle?
Results 1 to 6 of 6
    Sep 2014
    51
    Hey guys (and girls - if any..)
    I was wondering...
    1: - is it possible to use a stepper motor (was thinking Nema34) as the main spindle?
    2: - is it strong enough? (would like to have the ability to cut steel)
    3: - if so can it then be connected as the 4th axis so that it can be indexed?
    4: - do you have any experiences or thoughts about the project?
    5: - can it even run (continously) at high speeds (with acceptable torque) - maybe with belt/ gearing?
    by the way, it's a "simple" 3 axis mill I'm building... (if you could just answer one or some of the questions I would appreciate it!)
    Jan 2005
    1943
    Re: stepper motor as main spindle?
    1- No. Steppers lose torque as speed increases. above 2000 rpm or so it drops off fast
    2- No
    3- No. as a spindle the way it is commanded would ahve to be different, but it could be indexed. Would likely require special programming.
    4- No experience, but I wouldn't try it with a stepper
    5- Steppers can definitely run continuously, but not for a spindle.
    35538
    No, no, no, no, no.
    The faster a stepper spins, the less torque it has. At high speeds, steppers have almost zero torque.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2014
    51
    ok., guess that's off the table then.
    any recomendations on choosing a spindle then? guess I'll go with VFD as everyone else then
    - can VFD spindles spin both directions?( - you can't do thread tapping with those can you?)
    as said I would like the ability to cut steel, what are the price range/ cost then?
    Apr 2013
    1899
    Quote Originally Posted by teglberg View Post
    Cutting and tapping steel means low RPM and very high torque. So, forget about cheap Chinese spindles. Also forget about cheap DIY machine. You need weight and rigidity, and a lot of that. A machine like that weights over a ton, so be prepared for very high costs as well. Personally I am not even dreaming about steel.
    Yes, a VFD can turn the spindle in any direction. Rotation direction change with three phase motors is very simple, you just swap two phases and the direction is changed. That's an easy task for a VFD since the phases are just "faked", created by electronics inside the VFD. But again, tapping steel demands very high force at low RPM, which can't be done with cheap spindles, at least not the ones which run up to 24k RPM. Those spindles lose torque at very low RPM.
    Sep 2014
    51
    Quote Originally Posted by A_Camera View Post
    Okay the tapping isn't necessary, but I would still like to cut steel (occasionally) can it be done within a reasonable budget? The structure of my machine is very rigid...
  1. electrical problem with stepper motor and ac spindle motor
    By pdsherathia in forum Stepper Motors / Drives
    Last Post: 01-31-2015, 07:19 PM
  2. spindle motor to heavy for the stepper motor...
    By paulosousa in forum Community Club House
    Last Post: 01-07-2014, 02:11 PM
  3. Stepper motor for spindle?
    By blades in forum Mini Lathe
    Last Post: 04-15-2010, 06:17 PM
  4. Stepper motor as a spindle motor
    By Arich0908 in forum Benchtop Machines
    Last Post: 04-12-2010, 06:39 PM
  5. stepper as spindle motor help
    By scotty001 in forum Mach Mill
    Last Post: 08-27-2009, 06:26 PM
