587,708 active members*
3,891 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > CNCDrive AC servo driver powering brushless motors?
Results 1 to 9 of 9
    Sep 2011
    474
    I was looking at these drivers and they have the same pinout required by my brushless motors.
    CNCdrive - motion controls
    I emailed the company but have not heard back (its been a week). By looking at the pdf manual I could swear they were meant for brushless servos. Can someone with more experience take a look and tell me if im on the right track?
    Dec 2003
    24220
    Re: CNCDrive AC servo driver powering brushless motors?
    They are intended for 3ph AC servo's, drives such as A-M-C Copley and Aerotech will run a DC brushed on their BLDC drives.
    Al.
    Albert E.
    Sep 2011
    474
    Al.
    My brushless servos are 3ph as well.
    Dec 2003
    24220
    There is a subtle difference between AC servo and BLDC, the motor are practically identical, just the means of commutation is different, both brushless..
    Al.
    Albert E.
    Sep 2011
    474
    Al.
    Right. DC uses square wave from the hall sensors and AC uses a sine wave? Is there a sure way to tell them apart? Mine are 170V, 18A, 3000W. This seems incredibly powerful for a NEMA 34 motor around 5" long. Here's some pics, including the standard A,B,Z incremental encoder on the back.
    Attachment 325752
    Attachment 325754
    Attachment 325756
    What kind of driver would be appropriate for such a motor?
    Sep 2010
    1765
    Drive you picked will work fine. Realized at 50 volts you will only get 1/4 top speed from your motor
    Sent from my SM-G900V using Tapatalk
    Sep 2011
    474
    Quote Originally Posted by mike_Kilroy View Post
    Would something like this be a better match?
    Logosol LS 173cm 2010 Servo Driver Motor Controller Tested Functional | eBay
    Sep 2010
    1765
    Quote Originally Posted by SwampDonkey View Post
    Yes, it will get you to 1/2 max speed now... you still need to buy an ac to dc 80v power supply and w/o the pdf manual ahead of time, there is no guarantee it will interface to YOUR stuff. You did not say what interface YOU need? +/-10vdc speed command? velocity loop?
    it does 6 step commutation and that matches the motor design MCG built (sold to ametek then discontinued). But sine commutation will work too.
    so why not buy a drive for $ 200 that plugs into 120vac and does it all and gives you full speed?
    Sep 2011
    474
    I cant find a drive that matches these perfectly. Im sure I could buy a brand new drive that would do just that but im a "used and ebay" sorta guy (low budget).
  1. Servo motors not powering on
    By cncroller in forum Mori Seiki lathes
    Last Post: 12-31-2015, 07:14 PM
  2. Brushless DC servo motors with gearheads
    By SwampDonkey in forum For Sale Only
    Last Post: 05-31-2014, 04:50 AM
  3. Emerson DC Brushless Servo Driver Help?
    By MMMWWWPPP in forum Servo Motors / Drives
    Last Post: 12-20-2013, 02:23 AM
  4. An unidentfied box of brushless servo motors
    By paul3112 in forum CNC Machine Related Electronics
    Last Post: 11-02-2009, 11:04 PM
