First chips under CNC!
The sidewall finish isn't the best but I realized after the fact I had cam bam set to conventional milling for that profile. I also didn't set a deep enough depth for the thru holes and left them with the same .005 remaining stock on the bottom to clean up in post machining.
Time to do limit switches, pump and light wiring, and gas struts next.
Sent from my VS985 4G using Tapatalk
