Just updated LinuxCNC and had to do a clean install as I was on ubuntu 10.04. Trying to do stepcnfg wizard using the same settings I had written down from my old config. It will not home anymore, I have tried adjusting several settings in the wizard to no avail. It goes to the home switch, starts to back off, then errors with 'home switch active before latch move' I have spent the better part of the day trying to find answers but I dont understand linux well enough to understand what i am reading and if it even applies to my issue.
I am running from a parallel port through a BoB to gecko 540's, have micro switches for limit and home, they are set up as n/o which i know is not how they should be done, but they did work this way before.
Thank you for any advice
