Hi All,
I have a x-700 from Redsail in China.
All set up but being asked for a password when trying to connect to the laser via USB.
Contacted Redsail but thought might be quicker here!
Thank you!
Hi All,
Thank you!
To clarify it is asking for a password when I try and set "Machine Parameters"....I want to load the machine config file supplied with the laser.
Thank you!
I use AutoLaser but don't have it linked to the Computer as I save everything to a USB Drive and run it from there so never tried setting things up from the computer. When it asks for a Password, try 0000 , 1234 etc as a lot of times its a standard password.
Hi Ken,
Good suggestions! =)
The password is tz0001.
It is not needed to connect via USB but it is needed to adjust the "Machine parameters"....I thought this might be needed by the AutoLaser software but it seems it is just the config the machine.
My file (loaded via USB stick) is acting weird. It seems to flip the image sometimes but not others.
