587,426 active members*
4,699 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Using small end mills on a lower-RPM machine (PCNC 1100)
Results 1 to 18 of 18
    May 2016
    16
    I'm making some folding knives on my PCNC 1100, and in order to machine the lock bar (pic here) I'm using a 1/16 end mill, .25" flute length. And I'm having trouble determining the best feeds and speeds given the Tormach's 5100rpm spindle limit.
    I plugged the end mill geometry and specs (mfg recommends 500SFM, 0.001 chip load) into GWizard, and it's recommending a speed of around 25k RPM. From what I've read, that's generally where these small end mills perform best at. Unfortunately, my machine can only do 20% of that.
    If I limit the speed to 5100RPM, I'm having a really hard time getting reasonable feeds and depths of cut out of Gwizard without seeing the tool deflection number go red. It's suggesting a feed of 1 IPM with a 0.01" depth of cut. At that rate, my lockbar cut would take over an hour. And the tool is moving so slowly that I'd be concerned about rubbing.
    Any best practices to keep in mind when using small end mills on a low-rpm machine?
    Re: Using small end mills on a lower-RPM machine (PCNC 1100)
    You must not have GWizard set for a PCNC1100 if you are getting that high of a rpm.
    I have cut some features using a 1/16" end mill in steel and aluminum with my 1100, I used GWizard and ran quite a few of the parts. Depth of cut is the critical part of GWizard, everything else it figures out great. I have 100% faith in its outputs. Just remember GIGO.
    I always rough my material down with larger end mils and then finish with the smaller to get the needed small radius cuts, another trick is to drill out the corner first.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
    Aug 2007
    701
    On my machine (novakon pulsar) I cut the lockbar at 5200rpm and about 1 IPM w a 1.8mm (0.07) 4 fl endmill in titanium. It takes about 30min to cut. . It's too small a cut for any hsm strategies so it's straight my slotting.
    May 2016
    16
    Quote Originally Posted by R.DesJardin View Post
    I did temporarily override the max RPM setting to see what GWizard would recommend *if* it wasn't RPM-constrained.
    May 2016
    16
    Quote Originally Posted by brianbonedoc View Post
    On my machine (novakon pulsar) I cut the lockbar at 5200rpm and about 1 IPM w a 3mm (.078) 4 fl endmill in titanium. It takes about 30min to cut. It's too small a cut for any hsm strategies so it's straight my slotting.
    Interesting, thanks for that example. What depth of cut were you running?
    Jun 2008
    1082
    Just for clarity, was it a 2mm end mill or a 3mm end mill?
    Feb 2016
    381
    Total novice with no experience but when I was limited to 5000rpm and using sub 3mm mills I had most success with 1 or 2 flute mills allowing me to increase feed rate to prevent rubbing.
    Aug 2007
    701
    OOPS - I meant a 1.8mm end mill. Corrected post above.
    I just checked Fusion 360 and my recipe is this.
    Machining time: 10min 47s
    Feed distance: 42inches
    1.8mm 4fl TiN coated EM.
    5200 rpm
    0.00019 feed/tooth
    DOC= 0.035
    Slotting
    4 ipm
    Sep 2009
    624
    It is literally a trivial exercise to add a 30K rpm 1 hp router spindle to the 1100, co-linear with the main spindle. The cost is about 8-9" of the 17" Z movement, maybe 200 bucks out of pocket, and 4 hours to build. Use a DeWalt or other variable speed router spindle, and precision collets from Precisebits. No air or water cooling, no offset- X & Y axis has full range. Having built one, my 1100 has a speed range of 100-30,000 rpm. (I do need to add a breakout board to control the spindle with M codes- manually turning on right now). Given the length and typical DOC for small cutters, one is simply putting wear in a part of the Z axis that doesn't get used much. I use the high speed spindle for anything under about 1/8"; haven't had the nerve to try a 1/4" carbide cutter in Al at 10K. I'm running a 1/32 EM at 45 ipm, 0.018 doc slotting in acrylic, could probably do 60 ipm with no trouble.
    Build a high speed spindle adapter and have the best of both worlds- the envelope of the 1100 and more speed than the second gen speeder.
    Nov 2005
    218
    Can you post a picture show in your setup? If if I understood correctly you are saying that your router spindle is coaxial with the main spindle? How do you accomplish this?
    Mar 2009
    1863
    I made a plaque to go on my mother in laws casket when she passed away.
    I made it out of 1/8 X 4 inch brass bar.
    I ruffed it with a 1/4 inch end mill, then took the corners out with a 1/16 end mill then I engraved her favorite Bible verse with a .010 end mill.
    I bought 6 cutters and I busted 3 of them getting the verse done.
    Aug 2015
    368
    I run my 1/16 2f carbide bits@4ipm, usually only 0.02in deep, doing patterns, honeycomb pattern reverse from the knife shown previously it's basically ding a bunch of little pockets, I do 5ipm down to 40tho deep sometimes but I go firm to 4ipm to do engraving that is up to 20tho deep so I get a nicer finish. Here's done of the stuff I've done, the bb8 is 0.1in deep, I did that at 4ipm
    This one is 0.15 deep in every hole.
    I just got a tialn coated 2fl ball, most of that engraving was done with a ball end mill, I'll see how hard I can push that little guy and let you know if you want.
    Sent from my SM-G900V using Tapatalk
    May 2016
    16
    Quote Originally Posted by tbev View Post
    Looks pretty great. What machine and spindle speed was this on? Thanks!
    May 2016
    16
    Quote Originally Posted by GLCarlson View Post
    Very interested to see some pictures of your setup.
    Aug 2015
    368
    Quote Originally Posted by polar8 View Post
    Thanks bud,I appreciate it! That was 5140, whatever the max is on the 1100, it's my first machine, I've had it about six months now, I'm learning a lot still as well. If you haven't already played with your coolant system shoot me a pm, I'll show you what I did to mine, it's killer now.
    Mar 2015
    164
    Tbev please share your coolant system info/pics on this forum. I have a project coming up and very interested in learning how to accomplish this process.
    Thanks...-uman
    Aug 2015
    368
    Quote Originally Posted by Uman View Post
    Thanks...-uman
    I'm planning in on it,I just haven't had the time to do a proper write-up. I don't want to hijack tiffs thread bbuy i I will do a wire up
    Aug 2015
    368
    Thanks...-uman
    http://www.cnczone.com/forums/tormac...pc11-flow.html
    PC11 FLOW!
    Pics and vid, most of the things I did you can do for free.
  1. Replies: 0
    Last Post: 09-22-2015, 07:44 PM
  2. For Sale: PCNC 1100 3 Axis Mill -Series 3, Automatic Oiler (Machine Package 32383)
    By sewell in forum Complaints and Praise Discussions
    Last Post: 07-21-2015, 12:14 AM
  3. Tormach PCNC 1100 Series 3 (10 hrs on machine)
    By ark88 in forum For Sale Only
    Last Post: 03-29-2015, 03:15 PM
  4. WTS: PCNC 1100
    By HLF Ordnance in forum Tormach Personal CNC Mill
    Last Post: 07-13-2012, 01:41 PM
  5. PCNC 1100 Machine Arm
    By compunerdy in forum Tormach Personal CNC Mill
    Last Post: 10-11-2011, 12:23 AM
