587,793 active members*
3,842 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Can anybody recommend a good source for countersink drills?
Results 1 to 7 of 7
    Feb 2009
    237
    Have been trying to find a place where I can buy both of:
    1. 90 degrees spot drill AND
    2. 82 degrees spot drill
    or
    1. Drill Tip countersink drill for 6M screws AND
    2. Drill Tip countersink drill for 5/16" screws
    This is for aluminum so HSS or Cobalt should work fine.
    Thanks for any recommendation you may be able to offer!
    I document my CNC Experience at CNC Dude's Youtube channel. Check it out!
    Sep 2006
    6463
    Re: Can anybody recommend a good source for countersink drills?
    Incredulous..........you can't grind a drill?????
    Ian.
    Feb 2009
    237
    Hey man, I am a hobbyist, with no machining education, helping out a friend make some parts. Didn't even occur to me that is how professionals on this realm do it! May give it a try and see if surface finish ends up being acceptable.
    Jun 2004
    6618
    Here is a link.
    McMaster-Carr
    Lee
    Apr 2009
    5516
    Quote Originally Posted by CNC-Dude View Post
    or
    MSC, ENCO, Fastenal....
    Sep 2006
    6463
    Hi..........if you're going to have a go at grinding a drill, better do some dry running practice beforehand.
    A drill only stops cutting when the point is blunt.
    The knack of drill grinding is to get the off centre swing action that gives you the drill tip angle AND the back clearance or the drill won't cut but just rub.
    Take a fairly large drill.....12 mm diam would be OK.........and with the bench grinder NOT RUNNING, hold the drill in both hands....(left hand near the point and right hand at the end of the shank)......... with the point at the angle of the drill against the front of the grinding wheel.....not the side....and both cutting edges on the horizontal plane
    Practice the action that....... with the left hand holding the drill point against the grinding wheel....... forefinger resting on the grinding wheel rest.... the right hand rotates the drill point a half turn against the grinding wheel while at the same time it drops the end down slightly.....NOT TOO MUCH.
    If you want to see this action more clearly, mark the end of the drill with a black marker pen and hold the point against any flat vertical surface while doing the rotating swing action.........the marking will show you where the drill point touches the surface.
    The second important thing is to do this to both cutting edges as you go without too much on one edge, checking the angle with a drill gauge......this will enable you to get and keep the point on centre and at the right angle.
    Before you actually do any grinding, you'll need a drill point gauge.......which is just a piece of steel plate with an angled offset at the end to put the drill against to get the angle right.
    Normal drills are ground at 58 degrees per side.....you will need an adjustable angle gauge like a protractor with a moving rule that can give you the 45 and 41 deg angles.....(half the drill point angle per side).
    A quick tip to test the drill point for centrality is to lay it on a flat surface with the point against a vertical face and scratch it across the face, rotating the drill 90 deg each time.....it should have one line if the point is on centre.
    BTW...........do I have to tell you to use SAFETY GLASSES when on a grinder.......sigh.....OK, also make sure you have a can of water to FREQUENTLY dip in to keep the drill cool.
    Grinding little and often is a better way than forcing a blunt drill to work.
    Ian.
    Feb 2009
    237
    AHA! Thanks Handlewanker. This is great input! Will definitely give it a try.
  1. Which open source CAD/CAM software do you recommend
    By quantummachine in forum Uncategorised CAD Discussion
    Last Post: 08-26-2015, 07:20 AM
  2. Can any one recommend a good UK supplier
    By atkinsonp in forum CNC Machine Related Electronics
    Last Post: 11-02-2013, 04:32 PM
  3. How much do I have to spend for a good set of drills?
    By Bird_E in forum MetalWork Discussion
    Last Post: 06-05-2007, 04:26 PM
