587,517 active members*
2,810 visitors online*
Page 32 of 34 223031323334
Results 621 to 640 of 676
  1. #621
    Jan 2008
    932
    Re: 24" x 80" cut area, 8020 build...
    Quote Originally Posted by CarveOne View Post
    There is a setting for pulse width in the Mach3 software that has a wider pulse width option. Try changing it, saving it, then restart Mach3. See if that works. Use some blue thread locker on the set screw if you haven't done that already.
    I didn't find that, but I noticed in motor tuning that x and a were slightly different. Fixed that but didn't make a difference.
    Quote Originally Posted by Dan911 View Post
    I had same problem missing steps, and all started when using 1/16 ballnose with large a stepover. I fixed by shutting toolpath display off in Mach3. Easy test, maybe worth a try.
    with a large stepover? that seems strange... how do you shut the toolpath display off?
    Wood neophyte.
  2. #622
    Mar 2010
    813
    Mach 3 with large Gcode files can cause inconsistent problems resulting in lost steps. With a 1/16 bit with large stepover can produce a lot of lines of gcode and thought possibly this could be your problem. I spent days trouble shooting and turned out just shutting off display was the simple fix.
    I use 2010 screenset and there's a button on top of screen. Not sure for other screensets.
    Good luck
    Dan
  3. #623
    Jan 2008
    932
    I use 2010 as well.
    I changed the step pulse from 2 to 3 ... just to see... ran test two times with 1/8 bn and both times x0y0 stayed where it should (previously even 1/8th was losing steps) (10% stepover) ... So either just two lucky runs or that might fix it, have a long day of work tomorrow but will try the test again set for 1/16 bn and see how it goes.
    Thanks.
    BTW, anyone use that Leadshine MX4660 instead of the G540? Is it really that much better to warrant the price difference?
    Wood neophyte.
  4. #624
    Apr 2007
    8082
    Quote Originally Posted by Arbo View Post
    Mach3 standard screen set > Config > Motor Tuning > Step Pulse > 1 to 5 microseconds - try setting it for 5 microseconds if it is set for a lower value..
    CarveOne
    http://www.carveonecncwoodcraft.com
  5. #625
    Jan 2008
    932
    Yeah was set to 2, changed to 3 and it made a difference. Not sure exactly what that does, but guessing perhaps my computer is getting to where it can't keep up with the lower number? Dunno, Will shift it to 5 as well and see what happens when I get home from work today.
    Wood neophyte.
  6. #626
    Apr 2007
    8082
    The wider pulse shape probably gives the motors a squarer pulse shape in some cabling capacitance situations and pumps a little more energy into the motors to help give them a little harder "kick" while rotating.
    CarveOne
  7. #627
    Mar 2010
    813
    Hi CarveOne,
    Looks like raising this setting would give a more stable system regardless of having troubles or not. Do you know of any cons if any?
    With a quick google search I found a thread on it with some info, I copied and pasted a section Arbo may find interesting
    Quote Originally Posted by dfro
    You said earlier in this thread that the base step/dir pulse is 3 usec. The Gecko drive literature says that it needs a minimum 4 usec pulse width on one of the step pulse edges. If people are putting opto-bobs with opto-Geckos, I imagine problems with pulses not making it to the driver chips (and a lot of hair being torn out of a lot of heads). This could be clearly explained at 4.4.3 in the manual where you talk about opto-isolation or "5.2.3 Defining Special Features" (In fact this section defines nothing)..
    This was posted 2007 don't know what changes been made since than.
    Here's the link to thread.
    https://www.machsupport.com/forum/in...ge;topic=939.0
  8. #628
    Mar 2010
    813
    Just checked my settings and are already set to 5, I guess its the default setting for newer versions of Mach3.
    Thanks CarveOne, love this hobby/forum, always something new to learn.
  9. #629
    Apr 2007
    8082
    I looked at the Mach3 settings for my smaller 3' x 4' machine with G540 driver and it is set for 4 microseconds. If the issue is in the opto interface requirements, the end result will be still be that the motors are getting more recognizable pulses and they don't miss any steps.
    CarveOne
  10. #630
    Jan 2008
    932
    Am home now so will set to 4 and re-run the tests with 1/8 and 1/16 bn bits. Interesting though that if mine has been set to 2 since I built it, and never had this problem. Will let you know how it goes.
    Wood neophyte.
  11. #631
    Jan 2008
    932
    A couple quick tests done with the setting change, seems good. Running a longer one now (1/16 with 10% stepover, for about 9 inches)... if that passes, I will call it good. Now I'm thinking perhaps it's time to back up the HD on that machine, and swap out that PC with a newer one I have, The old one has been running out there dust covered for 7 years, and on occasion has issues starting up. Would be cool if one could find a nice little pc, small footprint, that had a db25 parallel port, rather than using these whole towers I have... save a little space and all. Oh, find that for a small amount of money, should of added that. Maybe hang the monitor on the wall as well and can get rid of some of my 'desk' space I have... just enough for keyboard and mouse.
    Wood neophyte.
  12. #632
    Apr 2007
    8082
    Good to hear it is working so far.
    CarveOne
  13. #633
    Jan 2008
    932
    It seems to work on the normal cutting. I have two pieces that match exactly for the finishing pass.. but hole cutouts and piece cutout are slightly off. Seems it goes to a rapid to move once done the finishing, so maybe steps are being lost in that rapid. Just finally found the config for the sherline mode, so running that to see what happens. Very frustrating when you actually want to use the machine but don't want to waste material.
    Wood neophyte.
  14. #634
    Mar 2010
    813
    Is this the same file that you first started losing steps with?
    How many lines of Gcode in file? Over 100,000?
  15. #635
    Jan 2008
    932
    I made a test one, that is basically a rectangle pocket, about 3 inches (in y) by 10 inches (in x) .. set for 1/16 bit with 10% stepover. Not sure the number of lines, will check, but I often do huge gcode files with way more than 100k lines. If that test works, will add some rapids to the end of it and see if that is what caused it (or if shirline mode fixed it).
    Wood neophyte.
  16. #636
    35538
    Sherline mode, I believe, basically sets the pulse width to 40us. Generally, if you need to use Sherline mode, then the issue is with your PC.
    Also be aware that with sherline mode, your maximum pulse rate is effectively cut in half, and may limit your speed. (IIRC)
    But sometimes issues like this can be very difficult to diagnose, and many things can cause problems.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  17. #637
    Jan 2008
    932
    Yeah, I am tending to think a good bit of it is my old PC. I just placed an order at newegg, mb, memory and case. After investigating a bit it seems modern integrated graphics is fine. I have loads of HDD's sitting around so will be set to load up win xp (why bother with newer if it's just running the cnc and you know it works) and get it all set, and save a lot of space. All in about 140 with shipping, not bad.
    Wood neophyte.
  18. #638
    Mar 2010
    813
    Can you please amuse me and try turning toolpath display off and try? The black and white square icon on top of screen.
  19. #639
    35538
    Another thing is to open task manager and monitor your CPU usage while cutting. If it gets near 100%, then you'll likely have problems.
    The 2010 Screenset, due to the larger toolpath, can actually be much resource intensive than the default screen. I've had 2-3 user that needed a new (different) PC to run it, even though they ran the default screen just fine.
    Gerry
  20. #640
    Jan 2008
    932
    I turned off sherline and went back to a 2 for pulse and tested, didn't mess up. Gonna take out one of the cut files that did and run that with screen on, see if it jacks up, then with screen off.
    Well I have a new faster one on the way. Just seems odd this just started occurring. No settings changed, nothing changed. That's what leads me to think it's in old electronics.
    Wood neophyte.
  1. New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105
    By Modular CNC in forum Open Source CNC Machine Designs
    Last Post: 11-25-2013, 12:57 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. First build 8020 60"x24"x5" Board Shaper
    By dlyork in forum DIY CNC Router Table Machines
    Last Post: 09-07-2010, 02:32 PM
  4. Replies: 0
    Last Post: 10-27-2009, 08:25 PM
  5. Milling - Need 90" X 24"+ X 1" in alum - in NW area
    By ChinookR&D in forum Employment Opportunity
    Last Post: 04-15-2009, 12:46 AM
