587,608 active members*
3,607 visitors online*
Thread: BT30 Spindle
Page 5 of 29 3456715
Results 81 to 100 of 570
  1. #81
    Mar 2014
    1132
    Re: BT30 Spindle
    What is the OD of the main housing on most BT30 spindles? I'm asking because my main bearings are pushing me for a big housing. The bearings are 75mm OD so when I cut the housing 90mm then I'll have 7.5mm wall. And I'll drill 6x 4mm threads for the outer part of the labyrinth seal. So that the 6 holes will be weak points. In short I have 2 choices: 90mm or 95mm housing. Please see the attached render. What do you think?
    Another question: is stainless steel acceptable for the housing?
  2. #82
    Jan 2005
    15362
    Re: BT30 Spindle
    Quote Originally Posted by Azalin View Post
    303 stainless or 416 stainless are both free machining and ideal for most things like this, you want at least a 6mm cap screws in the front cover, this is not only part of your labyrinth seal, you need good strength for your bearing preload also, so 4mm cap screw is not enough for a bearing of this size, bigger the better in that area, you can step out the diameter of front section for a length of 20 to 25mm, just so you can use a good size cap screw, around a 12mm or more wall thickness in the front where you need the cap screws
    When you machine the housing for you Bearing fit, make sure the housing is cold before you do the final measurement, and then cut for your Bearing fit
    Mactec54
  3. #83
    Mar 2014
    1132
    Re: BT30 Spindle
    Where do you mean exactly?
    Sent from my GT-I9300 using Tapatalk
  4. #84
    Jan 2005
    15362
    Re: BT30 Spindle
    Something like this
    Mactec54
  5. #85
    Mar 2014
    1132
    Re: BT30 Spindle
    OK I get it now. Thanks.
    I made the button (the part on the top that the cylinder pushes it down) however I've made a mistake on the dimensions so I'll make a new one tomorrow.
  6. #86
    Nov 2012
    29
    Re: BT30 Spindle
    Most of them have 90mm OD.
  7. #87
    Jan 2007
    317
    Re: BT30 Spindle
    What about threading the upper o.d. of the lower labyrinth seal and the lower end of the spindle housing, then just screw them together? That's how I got mine designed now. I'm using cast iron for my housing as it was the cheaper alternative. But like you. my lathe isn't long enough to bore through the 12" long piece. So I'm farming that out as well. My plan is to go ahead and make the lower labyrinth seal with the threads and let whoever gets the job of making the housing use it as a gauge.
    If I recall correctly, that hunk of cast iron is 4" in diameter. My finished part will be 3.78" or 96mm in the area of the lower bearings and step down to 2.95" or 75mm. I've bought matched pair bearings, so I don't have the spacer between them like yours. The larger portion for the bearings on mine is 2.24" long. That dimension is a moving target right now and the only one that isn't firmed up. My lower labyrinth seal is intended to sit flush with the bottom of the housing, but not cover it at all. That way if there's a bit of mismatch after tightening into the bearings it's no big deal. a small set screw coming in from the side of the housing is what I intend to use to lock the labyrinth seal in place. I 'm going to bore two holes in the lower labyrinth so I can use a pin wrench to tighten it in place. They will be blind holes though.
    Your project is looking good so far, keep up the good work.
    Bob
  8. #88
    Oct 2012
    342
    Re: BT30 Spindle
    My Chinese BT30 spindle is 90mm OD on the nose and the main part of the body.
    -Dan
  9. #89
    Mar 2014
    1132
    Re: BT30 Spindle
    I need some suggestions about taper cone. It is a perfect fit with the taper now but it isn't grounded. I can try to grind but I fear that I'll mess it up because the grinder must be perfectly centered on the Y axis. Otherwise the taper will play inside. It is a risk for me. So what should I do? Grind and success or trash it or leave it as it is? There is no one who can do the grinding for me in my area.
    Thanks Dan. What is the size of the thinnest area in the nose? And front bearing OD?
  10. #90
    Oct 2012
    342
    Re: BT30 Spindle
    What CAD software are you using? I might be able to save off a copy of my spindle, I have modeled most of the parts in Solidworks.
    Bearing is 68mm and the OD of the housing is 90mm, so 11mm wall thickness.
    -Dan
  11. #91
    Mar 2014
    1132
    Re: BT30 Spindle
    Nice! I have SW too. I'll PM you my email.
  12. #92
    Oct 2012
    342
    Re: BT30 Spindle
    The model is now on GrabCAD located here.
    https://grabcad.com/library/chinese-bt30-spindle-1
    -Dan
  13. #93
    Mar 2014
    1132
    Re: BT30 Spindle
    Thanks Dan.
  14. #94
    Mar 2014
    1132
    Re: BT30 Spindle
    It took my 2 days to setup the lathe for grinding the taper cone to the right angle. I used an aluminium piece as donor. I'll do the real grinding tomorrow.
  15. #95
    Mar 2014
    1132
    Re: BT30 Spindle
    @Mactec54
    What about this one?
    I kept the 90mm OD but added a flange as you suggested. Length is 30mm and holes are for M8 bolts.
  16. #96
    Aug 2004
    782
    Re: BT30 Spindle
    Was the wheel static and you ran the spindle ?
  17. #97
    Mar 2014
    1132
    Re: BT30 Spindle
    OK the taper is grounded now. I believe it has almost zero run-out and about 4.2mm drawbar travel from close to open which is what I wanted. Now I can move on to the next part. The main part of the labyrinth.
  18. #98
    Nov 2012
    29
    Re: BT30 Spindle
    The best way to grind taper is to grind it on its own bearings. May be it will be necessary to regrind taper after assembling.
  19. #99
    Mar 2014
    1132
    Re: BT30 Spindle
    How do they do it? On the lathe or mounted on the mill?
  20. #100
    Mar 2015
    6
    Re: BT30 Spindle
    You need to put the spindle in place to the mill where it is going to be used and grind it there.
    Here is Stan was doing that https://www.youtube.com/watch?v=CFAkb93_V3M
    BTW. So cool thread. Looking forward to see it finished
  1. Bt30 or bt40 spindle
    By KKamel in forum Spindles / VFD
    Last Post: 12-14-2015, 10:03 PM
  2. BT30 Spindle Help
    By Momentz in forum Benchtop Machines
    Last Post: 11-03-2015, 01:08 AM
  3. Looking for a BT30 Spindle
    By xtwalt in forum Uncategorised MetalWorking Machines
    Last Post: 11-20-2012, 10:10 PM
  4. BT30 Spindle
    By dirtridn2010 in forum Tormach Personal CNC Mill
    Last Post: 05-07-2012, 11:19 AM
  5. Reasonably priced BT30 ATC spindle.
    By dwalsh62 in forum News Announcements
    Last Post: 05-12-2011, 05:59 PM
