587,138 active members*
3,669 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Milling a profile from outside the stock milling inward towards the center
Results 1 to 6 of 6
    Oct 2009
    254
    Hey guys, trying to learn 360 here. I need to figure out how to mill some round stock. Need to lead in from outside the stock and then begin removing material inward. Basically making the round stock a smaller diameter. I've tried 2D Contour & Circular tool paths. It will mill the outside of the material but can't figure out how to work my way inward. What toothpath do you recommend to get me started here and can you advise what to do to get me started.
    edit: I have Bobcad v28 and can do this very task with a profile called Outside Profile. I can mill from the outer diameter of my stock and mill inward to a given point. What is the equivalence of this toolpath in 360.
    Thanks for the help.
    Feb 2009
    311
    Re: Milling a profile from outside the stock milling inward towards the center
    Quote Originally Posted by Rotax91 View Post
    2D contour and circular should do what you want. I assume you are selecting the inner profile to machine to? Can you post your part, or at least a screen shot?
    C|
    Oct 2009
    254
    Hello Cygnus- I worked with it a bit more tonight and got further with it. I'm very close. This is a sample part to figure out the concept before I go further. You can see the toolpath doing multiple steps inward. Now I just need to figure out the number of roughing passes and number of step downs.
    Thanks.
    Attached Thumbnails Attached Thumbnails 2016-02-24 21_52_42-Autodesk Fusion 360.jpg
    Feb 2009
    311
    Thanks.
    Looks like you're getting there. Here's a cool trick you can use with 2D contour: On the tab where you select the profile that you want to cut to (geometry), click the box to enable "stock geometry" and select the outer profile that represents the material that you're starting with. When you do this, Fusion will trim out any extra passes that are outside of the stock boundary. So when you set the stepover, you don't need to know exactly how many are required, you just set the stepover distance you want and then set the number of stepovers to some value that you know is too many.
    C|
    Oct 2009
    254
    Hi. That worked fantastic. I tried what you said about the 'stock geometry' It really shaves off unnecessary extra machine time. I really do like F360. I like the CAD side of it so much better than Bobcad v28. That said the CAM side of BC is pretty darn good.
    I appreciate the help.
    Jun 2016
    12
    Use high speed machine only take 2 min
  1. RFQ Profile milling
    By captainDL in forum North America RFQ's
    Last Post: 07-10-2015, 04:25 PM
  2. Side Profile Milling
    By KrisCapeTown in forum EdgeCam
    Last Post: 02-19-2014, 09:53 AM
  3. 2D Profile Milling
    By jemarkey in forum BobCad-Cam
    Last Post: 01-10-2013, 08:18 PM
  4. Profile Milling accuracy
    By Garban in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-03-2012, 05:28 PM
  5. Profile Milling?
    By xy_eezy in forum Dolphin CAD/CAM
    Last Post: 06-13-2010, 06:45 AM
