Originally Posted by
high-side
Handle, your way over complicating this....
I leave a 1" Jo Block at the machine for touching off the tools Z height at the top of the material, part, etc. Here's how I do it:
1. Jog the Z axis down to slightly less than 1" of the top of the material/part.
2. Set the 1" Jo Block on the top of the material/part
3. With my Pendant in one hand, and the Jo Block in my other, start jogging the Z axis UP/POSITIVE in small increments till the Jo Block will just slip in between the part/material and the cutting edge/insert of the tool.
4. Now, set Z the height on your controller, (mach3, or whatever your using) and input the extra 1" Negative from the Jo Block.
This method is simple, safe, and fast. No jamming tools coming down, no fancy gadgets needed.
