587,442 active members*
3,067 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Need help building a 30hp balanced RPC for a CNC
Results 1 to 8 of 8
    Aug 2012
    113
    I picked up a hardinge conquest 42 with a 10hp (7.5kw) spindle. Looks like it requires about 60 amps for 115% full load. The guy I got it from said he ran it off a 50 amp breaker and it ran fine.
    Probably picking up a 30hp motor tomorrow. Anything specific I should be looking for when I get the motor? The plate on the motor said it requires 78 amps. Will this also be the case if I'm just using it as an idler?
    I guess my first question is how do I calculate a rough estimate for how many and how big capacitors I should get.
    Sent from my SM-N920V using Tapatalk
    Dec 2003
    24223
    Re: Need help building a 30hp balanced RPC for a CNC
    Do a search for the old Fitch Williams RPC design, it should have the tuning features included.
    Al.
    Albert E.
    Aug 2012
    113
    I've been doing some reading. Seems like people are recommending about 15uf per 1 hp on the run side. Does that sound about right?
    Aug 2012
    113
    Also should I run a separate 220 line for the first 2 phase to the machine from the panel box and use just the rpc for the generated phase?
    Jan 2015
    138
    The Fitch converter:
    404 Not Found
    The past two times I edited this post, the URL was magically changed to cnczone. Here it is in words:
    www dot cnczone dot com slash FitchWConverter dot pdf
    No idea why it gets changed.
    Third attempt. Something is autoediting my post and changing the word "practical machinist" (with NO space) into "cnczone". I have attached the pdf.
    Aug 2012
    113
    I found it and read it thanks.
    Aug 2012
    113
    Is trying to run a 30hp with say a pony start a stretch for 100 amp service? The load Motor is 10hp and takes 22 amps. I also have 2 servos which are 7.6 amps.
    Jan 2007
    229
    Quote " 15uf per 1 hp on the run side..."
    15 didn't work for ME, but 17 did.
  1. Replies: 0
    Last Post: 03-09-2015, 03:51 PM
  2. FABTECH 2014: Titanium-Cut CNC Plasma Table with Two 5-Axis Bevel Heads & 30HP Drill
    By DDelaney in forum Trade Shows / Webinars / Other Events
    Last Post: 12-11-2014, 06:58 PM
  3. 30Hp phase perfect convertor large enough for a Qt20 ?
    By elohim1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-27-2011, 09:37 PM
  4. Building and setting up a balanced RPC
    By higgo in forum Phase Converters
    Last Post: 09-09-2010, 08:28 AM
  5. New Photos! Horizontal Boring Mill (30HP)
    By mzartop6 in forum CamSoft Products
    Last Post: 09-12-2006, 02:11 AM
