"Between 2 curves" is probably the most ideal and is part of multi axis as Mike suggests. However, the technique I use for working on round overs with equidistant offset is nearly as good since you establish a drive surface that starts it out in a smooth path, which helps all subsequent paths add stay smooth as well. Z-level can work, but the Z lifts and leadins/leadouts will be excessive on complex shapes with a lot of Z variaton. Really, you have to look at each job with fresh eyes and determine what will suit that task best based on the unique shape it has.
