587,765 active members*
3,718 visitors online*
Results 1 to 7 of 7
    Dec 2012
    161
    Reading from log files for probing?
    In a previous thread (http://www.cnczone.com/forums/tormac...4-tormach.html) TBKahuna used the commands:
    (PROBEOPEN //home/operator/gcode/Probe/probe-results.txt)
    (PROBECLOSE)
    To write the results of probing to a log file, probe-results.txt. Is there a way to read values from a log file into a program as a variable?
    I have a fixture where I probe several locations and store them. The only current problem is that if I need to stop the program for any reason, all my probe locations are lost. It would be nice if I could probe once, store the results in a separate file, and then read those values from the file and store them as variables. Would there be a more straightforward way of doing this?
    Oct 2014
    97
    Re: Reading from log files for probing?
    Thats a powerfull procedure , when it gets figured out, FuriousGeorge .
    Thanks for bringing the process into some focus, we will be hearing more about this....soon I hope
    Dave Lawrence
    Oct 2005
    1145
    instead of storing them into the Probe file simple copy each location into a Variable(#Var) Say X = #100 Y=101 Z= 102 then each probing pass increment teh value up 1 sequence.
    (;-) TP
    Oct 2014
    97
    Quote Originally Posted by vmax549 View Post
    (;-) TP
    That sounds good.. I can't do it yet . This Guy Mike Lynch writes a programming column in Modern Machineshop magazine, has a book thatI d like to see
    "Parametric Programming for machine tools and touch probes" its $95
    Does anybody seen this book yet ?
    Dave Lawrence
    Apr 2013
    1788
    The Lynch book is from 1996 so it is based on 10-year old technology. You can see the Table of Contents and index plus read some if you lookup the book on Amazon and select "Look Inside". Using the "Surprise me" option It frequently talks about Fadal's version of gcode.
    Jun 2006
    3063
    Quote Originally Posted by kstrauss View Post
    Even worst than that - it's based on 20-year old technology.
    Oct 2014
    97
    Anyone have a copy of that book they would part with .....or loan ?
    Dave Lawrence
  1. Not reading some V5 CATIA files
    By stustev in forum Uncategorised CAD Discussion
    Last Post: 06-19-2015, 12:35 PM
  2. Reading .pst Post files
    By cbr_speedster in forum Esprit
    Last Post: 03-09-2015, 02:40 PM
  3. converting CT Scans [ dicom files] to cutting files
    By fiddlemakermike in forum WoodWorking Topics
    Last Post: 05-09-2013, 02:15 AM
  4. NEWBY HELP...Fagor 8055M not reading files
    By manyhats in forum Uncategorised CAM Discussion
    Last Post: 12-20-2007, 10:27 PM
  5. reading v20 files in 2007
    By Redwon in forum BobCad-Cam
    Last Post: 11-06-2007, 04:20 PM
