587,751 active members*
2,908 visitors online*
Results 1 to 3 of 3
    Jan 2007
    11
    4th axis attempt
    1st attempt at 4th axis, converted y to a in cam, drew rectangle on screen for visual cue, per instructions on cd, gives me my circumferance. toolpaths inside or right to the line, toolpath generated is bad 25ipm, a axis moves very slowly, 1 minute for 20 degrees of movement, when it makes a small cut then the y axis starts moving. i think my drawing or setup in cam may be wrong, when toolpath is generated the onscreen graphic in mach has a big loop in it that shouldnt be there. trying to attach drawing and mach graphic, unsure if i did it right,,,,
    Jan 2014
    100
    You must have a wrapping group. Are you setting your Z @ top of part? What version of Bobcad?
    Jun 2005
    656
    Re: 4th axis attempt
    You need to tell Mach the diameter of your stock if you haven't.
  1. Attempt at 5 Axis. Constructive criticism is welcome.
    By dfaszer in forum DIY CNC Router Table Machines
    Last Post: 03-06-2015, 11:36 PM
  2. My first attempt
    By gonzapa in forum Uncategorised WoodWorking Machines
    Last Post: 12-31-2009, 11:15 AM
  3. First Attempt help
    By sYmbot2 in forum Community Club House
    Last Post: 09-10-2008, 11:55 AM
  4. my first attempt
    By v2tiller in forum DIY CNC Router Table Machines
    Last Post: 06-28-2008, 06:44 AM
  5. A axis attempt
    By Konstantin in forum Uncategorised MetalWorking Machines
    Last Post: 07-26-2006, 11:36 PM
