587,171 active members*
3,163 visitors online*
Results 1 to 7 of 7
    Oct 2015
    20
    Ball screw lead torque
    I have a 140lb table 622 Newtons and have played with some online calculators and can't seem to get a definitive answer on torque and of what I should expect.
    Right now I have a 2.5hp 4000 rpm Brushless servo driving a THK C5 ball screw 2520
    Ball screw diameter is 25mm
    Lead is 20mm
    spec sheet says .05 efficiency (I think I'm reading that right)online calculators say use 90% for rough estimate
    I'm trying to figure out is if I should have gone with a 2505 ball screw instead
    Ball screw diamter of 25
    Lead 5mm
    This is load is a 30"x30" x.5 in Steel plate for the bed of my CNC machine.
    What kind of rapids can I expect out of this machine?
    What kind of torque can I expect of of this machine?
    What kind of accelerations can I expect out of this machine?
    Thanks in advance.
    35538
    Re: Ball screw lead torque
    At 4000 rpm, your machine would rapid at 80m/min. However, it will never have time to get moving that fast.
    Your motor should have a rated torque specification. Your acceleration will depend on the motors torque.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2014
    182
    with a 20mm lead and your peak torque probably in in the 3000RPM range - I would consider gearing down.
    Oct 2015
    20
    Attachment 298558
    Here is the spec on the motor sheet but I don't understand what it means by the torque. Is it saying that it is 4.8 inchlbs per amp.
    On the side of the motor it says 36 amps RMS peak at stall and 12 continuous amps at stall does this mean that I take 4.8 inchs and multiply by 36 amps which comes out to be 172.8 inch lbs which equates to 14.4 lbs of torque and on the spec sheet down at the bottom theres a (3) beside the peak valuve sqaure wave and the notations says torque per phase. So there is three phases does this now mean 43.2 foot lbs of torque
    How does this torque effect my ball screw lead torque.
    Apr 2012
    134
    Please give the length of your ball screw. The ball screw inertia can be more than your "load" depending on diameter and length.
    Oct 2015
    20
    My ball screw is 710mm
    Oct 2015
    20
    So I have a ball screw 710mm 25mm diameter and 20mm lead this would equate to 3150 inch per minute or 52 inches per second. This is way out of my range of speed. I understand this. Well in a perfect world where the load is nothing. But I do have a load and I don't want to go 52 inches in a second. I'm wanting to go more along the lines of 15 inches a second which would equate to about a 1-4 gear reduction. If I did choose a 4-1 gear reduction would my servo still be strong enough to accelerate a 200lbish load (adding and subtracting vices) in an awesome manner, (within an inch or two) or do I need to increase my gear reduction from 4-1 to 10-1. This would decrease my overall inches per second to 5.2 inches a second.
  1. Breakaway torque of a ball screw
    By sdfeter in forum Linear and Rotary Motion
    Last Post: 08-08-2015, 01:43 PM
  2. Help with Ball Screw Torque Calc
    By thegolfer in forum Mechanical Calculations/Engineering Design
    Last Post: 05-25-2012, 01:47 PM
  3. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. Ball Screw and Lead Screw
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2003, 03:06 PM
