Hi Guys,
I am working on a retrofit to an older KMB1 to use Mach. I have gutted it and almost finished rewiring with all new controls, VFD etc.
One thing I did not realize until later is that it looks like the lube pump was driven from a timed relay as well as the mechanical timer on the side of the cabinet. I have thrown away the relay board so I am hoping someone with the original relay board can confirm the part number and brand of the top left relay listed as LTR in the attached page from the manual. The associated 100k resistor would be what sets its time. I assume the way it works is that every period from the mechanical relay the timed relay fires and holds the pump on for a set time to allow oil time to flow.
Attachment 287242
Attachment 287244
Cheers
Chris
