Hi guyz,
After some turbulent months, I am back on track to start designing the machine.
I have done some research, and turns out 5 axis is a ***** to build up, specially for Iron and steel.
So basically I would go and build up a CNC router, and then add 4th and 5th axis.
What I have been breaking my mind, is the motors I would use for this machine.
Leadshine easy servos (closed loop steppers with digital drivers) are my favorites.
I would put this 86HS80-EC-1000 motor and its matchin driver HBS86H.
Idea is to put this 3 motors on each axis of the machine, and then add 4th axis, with this motor (or even 12 Nm motor) with direct ratio on rotary axis.
I was also thinking the 1:2 or 1:3 reduction via double steel wire reinforced belts.
What I am considering is this Leadshine sets, but I dont know how they perform, and would they be suitable for such application.
Link to motors and drivers.
damencnc.com - Closed-loop Stepper Systems
Help needed.
