587,754 active members*
2,970 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Invitation To Start An Open Source Path Pilot Group
Page 8 of 12 678910
Results 141 to 160 of 222
  1. #141
    Jan 2009
    234
    Re: Invitation To Start An Open Source Path Pilot Group
    Progress got it to load using the sim INI.
    Machines: Grizzly G0704 Mill W/ 3-Axis DRO | Birmingham 12X36 Lathe W/ CNC Retrofit PMDX-126/107 W/ESS 3ph W/ WJ200 VFD
  2. #142
    Nov 2011
    211
    Looking promising! I see you used the Lathe ini, any luck with the Mill ini?
  3. #143
    Jul 2007
    1602
    Quote Originally Posted by simpson36 View Post
    I am going to follow the path laid out by Traces a few posts back. Except that I just picked up another SDD to keep LinuxCNC completely separate from Path Pilot. I am leery of changing Path Pilot because I don't want to create any support issues for Tormach or myself.
    I have been collecting info in another thread, but probably it would be better if I moved here to continue my Path Pilot 'education'.
    Can anyone recommend a good tech forum for LinuxCNC?
    A lot of LinuxCNC support is done on IRC channel #linuxcnc on irc.freenode.net.
    bob
  4. #144
    Nov 2011
    211
    Finally got my router working under PathPilot, just a couple changes to make to the tool change routines to suit my machine by so far so good. I am a happy man at this point. Oh, and this is via parallel port, not a Mesa card
    https://youtu.be/ZgU57Zdec9I
  5. #145
    Jan 2005
    111
    What version of PP did you use as your host. was it 1.9.2 I would like to do the same for my router when I get it built.
    Dave
  6. #146
    Nov 2011
    211
    Dave, this is 1.9.2.
    Cheers
  7. #147
    Sep 2009
    1856
    racedirector can you give some pointer`s to how you got it done I am think of doing the same
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  8. #148
    Nov 2011
    211
    Hi Daniel
    Yup, I'll post my file with pointers when I have sorted most things in the next couple of days...
    Cheers
  9. #149
    Nov 2013
    33
    Good video ,good machine.cheers!
    AngelBlade air plasma cutter
    www.abplasma.com
  10. #150
    Sep 2009
    1856
    cool thank you
    [SIGPIC][/SIGPIC]
  11. #151
    Jan 2005
    111
    Race
    Watched the video. I note that the only tab I could see when you showed the PP screen was MAIN. Are all the other tabs there just not showing for some reason.
    OK I watched the video again and when you stopped the operation the rest of the tabs showed up.
    Dave
  12. #152
    Aug 2007
    701
    Can u tell me how you bypassed the Mesa card requirement/check that PP does?
  13. #153
    Dec 2013
    267
    Quote Originally Posted by brianbonedoc View Post
    Take a look at the PathPIlot launcher script. It's well written and easy to modify to remove that check... or just launch the LCNC GUI yourself and don't use the PathPilot launch scripts. Everything is in operator's home dir and runs out of the tmc softlink. The PathPilot launcher mainly adds functionality to flash the Mesa card and to handle deploying updates, neither of which you need.
    Keep in mind that any updates you apply from Tormach will overwrite anything you do.
  14. #154
    Aug 2007
    701
    Thx WTO!
  15. #155
    Jun 2008
    165
    Quote Originally Posted by wtopace View Post
    Hopefully, the modified files can be copied to a 'holding' area during updates and copied back afterward. I made modifications for the HAL and added 8 macros. I am going to move from 1.7.x to the latest ver, so I'll post back the results.
    I'm a newbee to LinuxCNC, but si far I'm finding it to be quite impressive. As expected for an open source software, a little digging and a few searches turned up a world of cool stuff.
  16. #156
    Mar 2014
    264
    Hi, is there a way to try path pilot with no machine , just in simulation mode , to play with the interface try some programm etc...?
    Waiting for a step by step instructions messaless hack , you do great works guy's .
    Is there any downloadable version available of the software ?
  17. #157
    Jan 2009
    234
    jips.
    Yes, Click Here
  18. #158
    Mar 2014
    264
    Quote Originally Posted by Contract_Pilot View Post
    jips.
    Yes, Click Here
    Fast answer ! Thanks very simple to acess the sim.ini
  19. #159
    Aug 2004
    244
    I am looking to try a linux cnc build with a mesa card and was wondering if any know what the spesc for the computer that Tormach sells are. Mostly interested in the motherboard processor and video specs. I assume that what they use works decently with the MESA card and has decent latency numbers. Thanks
    Everything in moderation, including moderation.
  20. #160
    Feb 2008
    644
    Quote Originally Posted by eman5oh View Post
    If you are building your own PC and want fanless, I would suggest one of the J1800 or J1900 based MBs
    say a ASRock Q1900M PRO3 or ASUS J1800I-A if you want a Mini-ITX with a PCI slot
    If you want a fast system with PCI,PCIE and Ethernet the known to work well with LinuxCNC with both RTAI and Preempt-RT
    I would suggest a ASRock H97M Pro4 and a G32XX CPU
Page 8 of 12 678910
  1. trouble crating a tool path group
    By dcutler35 in forum Mastercam
    Last Post: 03-09-2016, 04:25 PM
  2. Replies: 10
    Last Post: 12-08-2013, 02:15 AM
  3. Open Rail - open source linear bearing system
    By milatary56 in forum T-Slot CNC building
    Last Post: 06-09-2012, 02:07 PM
  4. Open SOurce Electronics start:
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 07-16-2004, 03:03 AM
