587,087 active members*
2,954 visitors online*
Page 1 of 3 123
Results 1 to 20 of 50
    Jan 2015
    71
    Tormach issue
    I have delt with this problem since I first received my machine (used). I'm sick of it. After I complete a run with a mill, the z axis begins to rise and the spindle and coolant turns off as it is rising to the tool change position. Sometimes, during this process I hear a thump in the machine, then the spindle starts back down and will not stop until it crashes or I hit the estop. It happens somewhere after the tool has risen 2 inches and before it reaches tool change position and at random distance. It is not in my code as it does it with code generated from Mastercam, and Sprutcam. It does it very randomly and not always on the same program or the same tool change within the program. I have talked to Tormach about this and have reloaded mach and have switched the drives around and it continues to do this only on the z axis. anyone ever had to deal with this or know a fix?
    Re: Tormach issue
    I believe it is the Mach software, I used to have the problem as well. Once I switched to path pilot all my issues went away. That one as well as others
    Jan 2015
    71
    Re: Tormach issue
    Thanks, Now that I switched to a vista pendant and cant switch to PP for a while. LOL just my luck.
    Sep 2012
    1543
    Re: Tormach issue
    I've dealt with it aswell. I turned down my acceleration a few notches, haven't seen it happen since. Of course you have to use SETSYS (Unlocked Mach), instead of the one Tormach gives you to use... Look in your tormach install folders to find it. or search. I run my tormach around 150ipm, I went to path pilot and couldn't' stand how slow it was, had to go back to Mach and deal with the small quirks, plus with Mach you can have Dropbox...
    Feb 2008
    644
    Re: Tormach issue
    Quote Originally Posted by BAMCNC.COM View Post
    Pathpilot will very likely run faster than Mach before stalling for a number of reasons
    ( one is a trajectory planner that does not violate acceleration constraints by large amounts )
    But to run faster than the defaults, you would have to modify settings that have been deliberately
    made hard to access (for good business and safety reasons)
    So to do this you would have to work around this protection (just as you have done with Mach)
    Jan 2015
    71
    Re: Tormach issue
    BamCNC, are you saying I need to purchase a new copy of mach to turn this setting down?
    Jul 2003
    1754
    Re: Tormach issue
    And using mesa hardware and pathpilot realtime os the pulse train timing is rock solid.
    Quote Originally Posted by PCW_MESA View Post
    Re: Tormach issue
    Do you have the Noise Suppression Kit installed? I had this issue as you said at random times too.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
    Nov 2007
    2151
    Re: Tormach issue
    Quote Originally Posted by samco View Post
    Agreed!
    and
    "So to do this you would have to work around this protection (just as you have done with Mach)"
    I was going to mention this in another thread, that the brianbonedoc was parsing path pilot setup to suite his needs
    Jul 2004
    1424
    Re: Tormach issue
    Quote Originally Posted by Strip View Post
    No, the license that you have for your Tormach version should work in the downloaded version from Newfangled Solutions website.
    Not to mention that you could just run the full copy of mach 3 in demo mode and see if it solves your problem when you turn down the acceleration. Mach 3 in demo mode will execute something like 500 lines of g-code.
    Tim
    Mar 2009
    1863
    Re: Tormach issue
    I had the same issue with my machine about a year ago. Turned out the Z axis stepper motor had gone bad.
    I spent hours on the phone with Tormach before they found the problem.
    At first, they replaced the control computer (I still use Mach 3). That didn't change anything so the next thing was to replace the stepper motor. That took care of the problem.
    The smartest thing I have done is I kept up the warranty on my machine. Yes, it costs me $450.00 per year, but when I had my Z axis problem the first thing they replaced was the control computer. That was almost $800.00. I don't know how much the stepper was, but I'm sure between the computer and the stepper the bill would have been over $1,000.00.
    Jan 2015
    71
    Re: Tormach issue
    Thanks for the input. I think the cheapest thing for me to try is to download the new mach program and try that first, If it doesnt fix it, I may swap a couple motors out.
    Feb 2007
    1538
    Re: Tormach issue
    Hi Strip. Reading your issue. Are you sure it is not your Z stepper brake? Mine does something similar well, ....the thump and coasting down bit anyway. Is the Z axis still live and able to jog during its descent?
    Keen
    When i had this problem i did the same thing You did Cheers.
    Sep 2009
    1856
    Re: Tormach issue
    down load M3 grab the start icon from C / M3 folder replace the one in tormach folder with the one from the M3 folder then you have access to all settings
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Re: Tormach issue
    The cheapest is the noise suppression Kit, it's been a few years but I'm pretty sure this solved my problems. It can only help your machine performance and reliability. I currently run Mach on one machine and PP on the other they both work great.
    Jan 2015
    71
    Re: Tormach issue
    Quote Originally Posted by keen View Post
    Keen
    The z axis is under power on it's decent. or seems to be, the stepper is whining like it is running.
    Jan 2015
    71
    Re: Tormach issue
    Quote Originally Posted by daniellyall View Post
    Can you elaborate a little more? I am not sure I fully understand what you mean.
    Dec 2008
    740
    Re: Tormach issue
    I can confirm that Pathpilot is definitely NOT slower than Mach3. I ran Mach at 145in/min for X and Y, 106in/min for Y (the numbers are odd due to conversion from metric). I have Pathpilot now running comfortably at 157.5in/min and 130in/min respectively. The limits are actually slightly higher for both Mach and PP but I backed off a little to ensure that I didn't run into any problems later. I don't cut at these speeds, I only use these values for rapids and jogging. I significantly increased the 4th axis speed under Mach 3 but I haven't tested this with PP yet.
    Step
    Sep 2012
    1543
    Re: Tormach issue
    Quote Originally Posted by TurboStep View Post
    Step
    You modified the stock Path Pilot, which is WHY yours isn't slower. (I didn't see an easy way to do that) Pretty sure stock Path Pilot is at or slower than 110ipm. I didn't feel like figuring out how to turn PP under Linux so I could have dropbox, it was just easier to put the Mach pc back in and start making parts. However IF PP is as easy as the unlocked Mach, then I would say Path Pilot is superior if you ONLY need that on the PC, I couldn't deal with only having Mach. I've looked into Smooth stepper before, has anyone managed a switch over?
    As for using Mach, just go into your C: drive (pcnc foloder or something) and find "setsys" and use that as your program, no need to download anything, it's just the unlocked version of the Mach you already have.
Page 1 of 3 123
  1. HSM Works Post issue for Tormach
    By pejaer in forum Autodesk CAM
    Last Post: 03-19-2015, 02:13 PM
  2. HSMExpress Post issue for Tormach
    Last Post: 03-18-2015, 01:56 PM
  3. Tormach License file issue
    By LRF in forum Tormach Personal CNC Mill
    Last Post: 09-02-2014, 10:12 PM
  4. Tormach and SprutCAM issue
    By kevinro in forum Tormach Personal CNC Mill
    Last Post: 01-29-2012, 05:36 PM
  5. Tormach / MACH3 Pause Issue.
    By RTP_Burnsville in forum Tormach Personal CNC Mill
    Last Post: 04-13-2010, 03:40 AM
