587,480 active members*
3,368 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > 4 Axis Mach 3 Postprocessor (free but kinda wip)
Page 2 of 6 1234
Results 21 to 40 of 104
  1. #21
    Aug 2007
    701
    Re: 4 Axis Mach 3 Postprocessor (free but kinda wip)
    Thanks for your work but can you upload the .gpp files as the VMID is just for the machine part of things.
    Thanks!
  2. #22
    Aug 2013
    189
    sorry about that, here is the pre processor. it's the same for both systems.
    best regards
  3. #23
    Aug 2007
    701
    Thanks!
  4. #24
    Dec 2010
    32
    Sorry for the double post. Had some issues with my cnczone account, now fixed thanks to Mark
    So I played around some more and almost completely rewrote bogan's postproc. I have set up a repo on github here.
    Due to video per post limit - here's one :
    And links to the others
    - https://www.youtube.com/watch?v=uzifjFm5B8s
    - https://www.youtube.com/watch?v=1xZXbI-XKnc
    - https://www.youtube.com/watch?v=U_YhK-_TQng
    Attached is a shot of the model that I use for tests.
    As a side note -- I find the free HSM Express Gcode editor and backplotter really useful.
    Cheers,
  5. #25
    Jul 2012
    49
    I've had a brief look, but I seem to have forgotten a bit about the machine setup as I haven't got it to machine simulation correctly. From memory there are some table offsets or something, jailbreaker can you give us a quick rundown of what you changed and benefits of? I could just compare files between mine/yours to figure out what offsets need changing but if you can remember that'd be even easier. I'm happy to defer to your updates and spend a bit of time testing em on a physical machine if they are better than my first attempt...
  6. #26
    Dec 2010
    32
    Ok, let me see if I can provide a list from the top of my head :
    • Cleaned up the post, removed a lot of stuff that I found unnecessary -- block number generation subs (no more calls to @gen_nb), unused .gpp params (like ONLY_XYZ and TEXT iirc). Generates cleaner and less redundant code according to me. At least more readable. Also operation messages are now correctly added to the resulting gcode along with comments and so on.
    • Streamlined the vmid, updated parameters of the drill cycles, used english names. Also added trace_level as a parameter so debugging is easier.
    • 5x moves - changed your trig math to using @tmatrix -- xtpos, ytpos, ztpos. Found that in the gpptool help.
    • For "3 1/2x" indexial moves added A axis repositioning between ops, so that when multiple CSes are at play the generated g-code does rotate the part in between operations. For reference you can take a look at the demo files I have added to the repo here.
    Now stuff to note :
    • MAC CS needs to be set so that the origin is on the axis of rotation.
    • Currently all sub- positions also need to have the same origin. They must have the X oriented in the same way, but Z and Y can point to wherever necessary. This solves indexial repositioning between operations. Like this Attachment 288200.
      This means that setting your CS like this
      Attachment 288202
      will not really work since CS offsets are not taken into account. I.e. the part does get properly rotated but whatever moves are there after are off by the origin offset of the new CS has to MAC. This needs fixing.
    • Determining if the part needs rotating between ops turned out to be harder than I thought so now I have hardcoded a retract to tool_z_level always (and that's in abs coords). Most of the time (almost always) this is unneeded and needs fixing
    Cheers,
    Teo
  7. #27
    Jul 2012
    49
    Sounds good, will run some test machining this weekend.
    I've got it doing machine sims as it should now; in vmid file I had to adjust the rotation center in you file (as expected) but the tool station was set to -1 Z direction, so the tool was simulated upside down. Not sure if that is meant to be -1 for some other reason?
    What are the trace level parameter options/functions?
    cheers
    John
  8. #28
    Dec 2010
    32
    No specific "reason" in mind. My understanding is that if Z, pointing up is 1, the tool pointing down should have an opposite vector -- i.e. -1. But since I'm a complete amateur. this assumption may be very wrong ...
    The parameter is called trace_level. You will be asked upon gcode generation. Default value of 0 produces no traces in the resultant file. Maximum value is 5 which is full tracing -- calls, parameters, values and so on.
    Cheers,
    Teo
  9. #29
    Jul 2012
    49
    I think it takes that into account somewhere else already.
    I've tried some 3axis with indexial CS and that works great.
    Tried some 4x and it didn't work at all. Took some rework of my simulation model and the vmid file to line those up so I was getting proper machine simulations. But the G-Code it spits out is wrong, my first try at the trig re-calc was also wrong (partially due to not having proper sims) which may have put you wrong. Anyway, this is what my 5x stuff now looks like
    @move_5x
    gcode = 0
    ; -z -a
    zpos_trans = cos(apos)*zpos-sin(apos)*ypos
    ypos_trans = cos(apos)*ypos+sin(apos)*zpos
    apos_trans = apos
    {nb, ['G'gcode], [' X'xpos], [' Y'ypos_trans], [' Z'zpos_trans], [' A'apos_trans], [' F'feed] }
    endp
    @line_5x
    gcode = 1
    ; -z -a
    apos_trans = apos
    endp
    I could not find where you got the xtpos etc from so couldn't figure out what was going on there.
  10. #30
    Dec 2010
    32
    xtpos, ytpos and so on come from something SC and gpptool call @tmatrix. Found out about it while tracing the post with trace_level above 1 I think. Then I looked in the help file (C:\Program Files\SolidCAMXXXX\Documentation). They say that these are the values the system pre-computes with "standard" setup, but if one has special requirements one can compute coords himself (like you do).
    I found the machine sim to be too fiddly to waste time on, since after all, the ultimate goal is to have mach3 get proper gcode, not just a fancy 3d image of a machine moving. For all I know, if you open a file generated with my post in mach3 it works properly in all operations -- 3x, indexial, 4x and 5x. You can see this in the videos I've posted in the posts above.
    But if you let me know what machine are you using for the sim I can try to get this to work too. I can PM you my email to send me the files or you can PM me a location where I can download them from.
    I think "not working at all" is the reason I had to have tool_z to be -1. I have had the same problems of paths that look extremely wrong and weird, but in my case they were so in the backplotter and/or mach3.
  11. #31
    Jul 2012
    49
    It might be because my machine coord sys is not on the rotation center of the 4th axis. It was certainly doing much larger 'arcs' around that center than it should have been.
    Your post has -180 on the Apos, and mentioned the toolpaths get inverted, you can change direction when you select the faces if that is what you mean. Also, the 5th axis seems to default to locking at 180 quite often.
    I'll have another try of some things later today, then see about getting you some files.
  12. #32
    Dec 2010
    32
    BTW, Does your trig. math work with off-center coord syses ?
  13. #33
    Jul 2012
    49
    No, but I'm not sure it should anyway, isn't part of the point of multi coord systems so you can clock it up to different features on the part.
  14. #34
    Jul 2012
    49
    I've got files for you, 25meg though, and I forgot my dropbox password... do you have one I could throw them into?
    Test cutting a triple helix in some 25mm plastic round bar. Quite slow, I think the feed speed translation in Mach3 might be assuming it has a larger working radius or something.
    Attachment 288894
    EDIT: Might have found the answer to the speed
    "You need to enter the rotaion radius on the settings page, in order for Mach3 to calculate the feedrate correctly.
    Now, this is not actually the radius that you enter, but the distance from Z zero to the axis of rotation. If you zero your Z axis to the surface of your part, then you will enter the radius.
    However, if you set Z zero to the center of rotation, then enter 0.001 for the radius. It should be 0, but entering 0 will disable this feature in older versions of Mach3.
    Also, make sure your steps/unit is set up as steps/degree."
    from How to speed up rotory axis
    It's still doing the job so I don't want to stop it, might try a repeat part with those settings to compare times (it's looking like around 4hr this time, instead of the 1.25 hours SC estimated)
  15. #35
    Dec 2010
    32
    Looking at the picture you posted I see that your A is "pointing" to the left -- in the -X direction. That would explain why you get issues with my post -- it's meant for A pointing in the other direction (+X). Meaning that rotation is also in reverse to your setup.
    I've PMed you a link to a dropbox folder, btw.
    Cheers,
    Teo
  16. #36
    Jul 2012
    49
    Mach3 handles rotation inverse for the A axis I'm pretty sure.
  17. #37
    Dec 2010
    32
    Sure, you can have it spin the axis in the other direction and that's a given.
    That breaks the right hand rule, though... Or it doesn't provided you have your setup for that scenario starting from the CAM, then sim, post and finally g-code.
    Edit: link to a pic with rhr pic.
  18. #38
    Jul 2012
    49
    Yeh I see what you mean, but everything works well now and I don't really use the A axis number notation enough to get into bad habits I think.
  19. #39
    Hello,
    can you give me for working postprocesor inventorCAM? I tried this postprocesor which is solidcam InventorCAM but not found in direktoriyata.Imam need for working postprocesor 3axis inventorCAM and mach3.
  20. #40
    Hello,
    can you give me a working postprocessor for inventorCAM? I tried this postprocesor which is solidcam InventorCAM but not found in the directory .Imam need for working postprocesor 3axis inventorCAM and mach3.
Page 2 of 6 1234
  1. Postprocessor Camworks to Mach 3
    By mazaracing in forum CamWorks
    Last Post: 02-11-2011, 10:29 PM
  2. 5th axis kinda
    By Delw in forum Haas Mills
    Last Post: 12-14-2010, 03:37 PM
  3. Mach 3 Postprocessor for SolidCam
    By Debos in forum Screen Layouts, Post Processors & Misc
    Last Post: 06-20-2008, 11:15 PM
  4. 2UVR x-axis powerfeed sorta kinda working
    By Stinson_Voyager in forum Tree
    Last Post: 01-14-2007, 08:11 PM
  5. 2UVR x-axis powerfeed sorta kinda working
    Last Post: 12-27-2006, 06:10 PM
