587,220 active members*
2,592 visitors online*
Results 1 to 4 of 4
    Jul 2015
    2
    Contour Milling Optimisation
    Dear fellow SolidCAM users!
    I think i will need Your help,
    I want to mill an almost sphere-like pocket on a 3 axis BZT.
    Of course I define the working area, and pick contour, the step down and so on in the roughing operation. It works ok, BUT!- when the tool starts from the OUTSIDE, and works itself to the inside on the same z level, when it finishes it lifts up, goes to the next z level on the OUTSIDE diameter instead of going to the next z level in the center since its already at the center (it came to there after milling the z level from outside to the inside). I have a very hard time understanding how to edit toolpaths;
    PLEASE- What is the proper way of making the tool do what I explained and want it to do?
    Oct 2013
    64
    Re: Contour Milling Optimisation
    What kind of op fo you use?
    Jul 2015
    2
    Hi! I used 3D milling, and i picked the upper contour of the spherical hole as the contour.
    Oct 2013
    64
    Hi. Sorry. Have poor experiance with 3d milling. More hsm ans hss.
  1. Z axis waviness artifact in contour milling
    By microns in forum Haas Mills
    Last Post: 07-09-2014, 09:00 PM
  2. Pocket Milling Problem - selecting contour
    By Outdoormoto in forum Uncategorised CAM Discussion
    Last Post: 08-18-2013, 05:46 AM
  3. Optimisation problem for 3D Milling
    By Shinobiwan in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-24-2012, 07:59 AM
  4. Milling 2D contour and clean up stock around it
    By scot1911 in forum BobCad-Cam
    Last Post: 10-03-2010, 09:18 PM
