587,321 active members*
3,091 visitors online*
Results 1 to 19 of 19
    6855
    Anyone building a laser
    Anyone working on building a CNC laser? I really thinking about building one, seams like their are allot of was to go about it. Here is a great design I came across.
    Nov 2003
    4
    I have had only limited experience teaching CNC milling to high school kids. Rather than make one, I would rather start with buying and modifying a 100+watt, CNC laser wood carver. I also need CNC software that would allow me to color portions of a picture that can be scanned by the same software to provide the depth data my high-pressure gas-assisted wood-cutting laser would cut on the z-axis. I welcome all suggestions.
    Ron Davison
    [email protected]
    Oct 2003
    127
    Interested party here.
    I'd be very much interested in finding out all I could about using LASER's for cutting. Building one, as well as operation.
    Would this be of the class iv or v type??? Newbie question.
    2139
    laser=$$$
    not just to buy, but to operate.
    Eric
    I wish it wouldn't crash.
    Nov 2003
    4
    How much money are we talking about to buy and to operate?
    Jun 2003
    1365
    I have seen a 64ftx12ft lazer, cutting 1" steel. forgot how many kilowatts, but it was over 500, maybe 5000. Dont really remember. The machine was a few million I bet.
    Jon
    2139
    a hundred watt co2 laser is around $5,000 used and the optics are expensive when you burn em out. $200-300 bucks a shot.
    Eric
    Nov 2003
    4
    I found a friend with an 80-watt laser that he used to etch out (~1/8" deep) his family tree on a mohagany slab; it looks great. I will get him to do etch the picture panels for the caskets and forget about high-relief carvings.
    Aug 2003
    8
    I believe http://www.co2laser.com sells (or used to sell) a sealed CO2 laser and components to integrate it into your existing CNC gantry mill. It has been a while, but my recollection is that the 35 watt version was only around $3,000.
    They currently (on the web site) sell a 25 watt laser "printer" which is a desktop box that will do 12" x 16" cutting or etching, around $10,000.
    Joe Dunfee
    Oct 2003
    399
    Look here for everything you ever wanted to know about lasers, and DIY lasers in particular:
    http://www.repairfaq.org/sam/laserfaq.htm
    The laser type to use for machining would be CO2 (gas laser) or YAG (solid state laser).
    Arvid
    Apr 2004
    30
    I've seen used SpectraPhysics 820 and 825 co2 lasers for under $25,000. There in the 1.5Kw to 2.5 kw range.
    I had an Amada lasmac 644, at my shop with and 820 laser and It cut 1/4" steel well.
    If you fine tune your focal hight and gas presure you can cut 1/4" steel well at 1100 watts.
    The main downfall to these lasers is there size. They have a footprint of about 6ft cubed + you need a large water chiller, and three gas bottles.
    sick minds demand sick toys!
    Jan 2004
    231
    Re: Anyone building a laser
    I am. I have archival entries of the system at my blog:
    http://nilno.com/laser_dir/blogger.html
    which contains flotsam that has collected during the course of the project. Right now I'm building the laser controller and motor drivers which requires a lot of custom electronics. I'm using Jon Elson's universal controller board:
    http://pico-systems.com/univstep.html
    gecko motor drivers, and digital encoders.
    The total estimated cost is about $12k. The laser itself was $6500, I bought a cnc table for $500, and the optics were another $2500. Other costs include 220 volt wiring, cooling and ventilation.
    This particular laser should be of sufficient wattage to cut sheet metal and 1/4 thick wood. I hope to use it to make: cheap cnc parts for members on this web site, artistic products to sell, engravings on glass work that my wife does, wood boxes, and high end lamps.
    I am guessing that the project will take around 6 months to complete.
    Owen
    15
    Check out Bobs site here http://www.emissiontechnologies.com/
    He has been selling CO2 laser kits and plans for a few years now.
    I work with 3 Trumpf brand lasers. 2600, 3000, and 5000 watt. The 5000 cuts up to 1" mild steel. They were each 1 million when new.
    Jul 2003
    246
    Did you try this homemade laser?
    Aug 2004
    3
    co2 tube source
    Information Unlimited is a good site to look at for laser tubes. I just bought a 20W CO2 tube for 395 bucks. I am planning on building a selective laser sintering machine with it so 20 Watts will be fine. If you want to do some cutting with it I believe that with the proper laser optics to focus the beam to the diffraction limited spot size (around 10 microns) you could cut thin metal with it. I have found that CO2 laser optics are somewhat expensive. Anyway, I hope the source mentioned above helps. I would have posted sooner but I just discovered this site.
    6855
    Quote Originally Posted by vortexdave
    Where did you get you're laser for that priice at??
    35538
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2004
    564
    Quote Originally Posted by ger21
    This guy is actually selling weapons! check out the laser gun.
    I think his co2 cutting kit maybe a good low cost intro into laser cutting, anyone bought one??
    6855
    I'm thinking of starting my own laser cutting machine, that tube would be perfect.
  1. Building a stepper motor.
    By tastefulasever in forum Stepper Motors / Drives
    Last Post: 12-11-2009, 05:50 PM
  2. feedback isolator for laser
    By owhite in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-14-2007, 03:34 PM
  3. [JOB] UK, Worcestershire CNC Laser job-shop
    By rszemeti in forum Employment Opportunity
    Last Post: 03-31-2005, 01:08 AM
  4. Laser Cut Steel
    By vacpress in forum Community Club House
    Last Post: 05-21-2004, 05:32 AM
  5. Rapid prototype CNC laser resin. (Stereolithography)
    By ynneb in forum Community Club House
    Last Post: 04-25-2004, 02:17 PM
