587,798 active members*
3,273 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Source of way cover wiper material for VM1?
Results 1 to 8 of 8
    Jul 2004
    242
    Has anyone dealt with this problem? I need to replace the wiper material in my way covers, not a big job in itself, problem is finding the wiper material. I estimate I need about 50 feet to do all of the covers, about 36" per wiper. I can get the material from Hurco
    P/N 6190001015, WIPER, WAYCOVER, VM1/2/3, $290/meter
    $4700 for rubber strip is asinine. I checked a number of the companies that make the material but none seem to have the profile used on a Hurco.
    Jun 2011
    695
    Re: Source of way cover wiper material for VM1?
    I would be interested in this answer also.
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
    Oct 2013
    64
    This link was way shorter before I cut and pasted it, but it's basically waywiper.com. There's been previous posts here before as well that may have other suggestions.
    Way Wipers, rubber wipers, slideways, way wiper
    Jul 2004
    242
    Here are some close up pics of the profile, it wipes with both a front facing lip & a rear facing lip and is retained by the hump resting in the channel.
    Attachment 286082
    Attachment 286084
    Jul 2004
    242
    Quote Originally Posted by deputydawg View Post
    No go, sent them a pic and they don't have that profile wiper.
    Oct 2013
    64
    I found another place that may have something. It's mimwaycover.com
    Jul 2004
    242
    I pulled a cover to remove a piece for a pic and measurement. It measures 12mm wide. The rear tail is about 3mm, middle 4mm and the lip about 5mm
    Jul 2016
    2
    Did you ever find any wipers that work? I need the same for a vm2.
  1. Does anybody have a source for aluminum gear material?
    By Fadal Error in forum MetalWork Discussion
    Last Post: 02-23-2015, 06:12 AM
  2. Worklight Cover - What Material to Use In Chips/Coolant Environment?
    By Hitachi Newbie in forum Maintenance DIY Discussion
    Last Post: 10-09-2013, 04:30 PM
  3. Replacement Worklight Cover - What Material to Use?
    By Hitachi Newbie in forum Uncategorised MetalWorking Machines
    Last Post: 10-08-2013, 09:44 PM
  4. Source for Ballscrew Wiper Brushes
    By kevincnc in forum DIY CNC Router Table Machines
    Last Post: 12-01-2012, 06:54 PM
  5. way cover wiper seals for our Haas VMC
    By bob1112 in forum Haas Mills
    Last Post: 01-15-2011, 03:50 PM
