if there is a tool change macro it will probably be numbered 9000 or higher.
you need to unlock the 8000 range and/or 9000 range programs by setting parameter 318.7 or 319.7 to 0 then power off/on and you will be able to see all the programs in memory. then just punch out the program you need.
