Electronics are complete and the enclosure is done, sans the lid. I also now have power to my mill again after stealing some components and the spindle direction switch for this build. All 3 axis spin and seem to work fine after generating some g code in CamBam but I don't have things configured right just yet for the ballscrew pitch I'm looking to use. Still trying to figure out where that setting is in Mach 4 as I've had no time to play with it hardly.
Everything in one shot.
Attachment 285602
Front Panel: Estop/Off, main power on momentary switch, spindle direction/power switch, coolant power light, coolant power off/on switch, xlr connection that will be for c10 estop and limit swiches, and my ESS Ethernet connection.
Attachment 285604
My attempt at cleaning up the wiring.
Attachment 285606
Hinges and dual cooling fans.
Attachment 285608
A,B,X,Y,Z motor plugs, and encoders below, spindle power connection, coolant pump connection, xlr is for work light dc power, and 220v inlet power is on the bottom.
Attachment 285610
The mill still in its torn down and in need of a cleaning state.
Attachment 285612
My bench testing helper.
Attachment 285614
