587,321 active members*
2,999 visitors online*
Results 1 to 6 of 6
    Dec 2005
    134
    Tool changer slams
    We have been running our new to us arrow 500 for several weeks but it seems like the tool changer slams compared to other machines I am used to. We have the air pressure at about 100 psi.
    Apr 2014
    20
    Re: Tool changer slams
    You can just adjust the flow screw on the fittings that go into the cylinder . I think you want to restrict the return side slightly - go a little at a time . - If you do the pressure side it might make it hang on the spindle .. This is what worked for me . Hope it helps
    Apr 2014
    20
    Or check that the spring loaded stopped is working( the thing with the lock nut on the back ) , mine was jammed in .. Some crc and a wash , fixed that .. So probably do this before adjusting flow screws . Sorry .
    Dec 2005
    134
    OK thanks!
    Dec 2006
    585
    Most arrow machines used an electric motor to advance and retract the tool changer disk. Does your machine use the older style air cylinder to do this??
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Dec 2005
    134
    supraman - that was it! Cylinder jam nut was loose. We had to make a wrench to fit it but everything is beautiful now! Thanks!
    Mike - it is definitely air. Thanks!
  1. Auto tool changer Drum type tool magazine.
    By maylin1105 in forum News Announcements
    Last Post: 02-18-2012, 09:44 AM
  2. Auto tool changer Armless type tool magazine.
    Last Post: 02-16-2012, 03:27 AM
  3. Auto tool changer-Umbrella type tool magazine.
    Last Post: 02-15-2012, 03:38 AM
  4. Head Go up and slams
    By DMAXAM in forum Fadal
    Last Post: 07-12-2010, 03:34 PM
