587,125 active members*
2,795 visitors online*
Page 1 of 3 123
Results 1 to 20 of 45
    Jun 2015
    17
    fanuc 6m locked parameters
    Hello,
    I have fanuc tape center model d with fanuc 6m control.
    the bubble memory has crashed and I replaced it with a new one.
    and I have put in all the parameters bud I can't change parameter 120 and 122, I need them for the tool change.
    I think that the are locked and the can only be changed by setting another parameter,
    does anybody has an idee?
    Greetings albert
    machine data:
    Fanuc tape center model d
    6m
    Series m63
    Typ A04B 0034 A003
    Ser 530432
    Feb 2006
    338
    Re: fanuc 6m locked parameters
    I'm assuming your manually entering them. Sometimes the order parameters are entered matter.
    Try loading the correct full parameters from a backup via rs232 or a memory card.
    Jun 2015
    17
    hello dpuch,
    yes I did it manualy.
    I don,t have a backup on the pc. I have tried to change by pcload, the communication works, I can change everything while adjusting parameter on pc and send them by rs232, but I can't change 120/122/123 it remains 0.
    I think another parameter must be set. bud I don't know wich.
    do you have another idea?
    Feb 2006
    338
    You may try clearing the memory again (remove the module) and starting fresh. Manually enter just the rs232 settings, then upload the complete parameters.
    If it requires a setting to be something besides 0 before it is uploaded then I do not know either.
    Aug 2011
    2517
    he mentions he doesn't have a backup on PC.
    I agree uploading the parameter file is a possible solution.
    it could be as simple as punching out the parameters, edit and upload.
    to do that, go to EDIT mode, press PARAM, type P-9999 then PUNCH.
    then edit the file, save then read it back into the machine by going to
    EDIT mode, press PARAM, type P-9999 then READ
    Jun 2015
    17
    hello fordav and dpuch,
    i have erased the memory, so all the parameters are zero. and i have set only the rs232 settings in de parameters, and then i have upload the parameters by pc.
    everthing is written bud the parameters 120/122 not, the can,t be changed.
    the error is : 451 t servo
    what i could find out that its for toolchange, and it needs parameters for that.
    any idees?
    greetings albert
    Jun 2015
    17
    this is what i found in the manual. alarm 451 t servoClick image for larger version.
ID:	283708Click image for larger version.
Name:	1 fanuc 6m.jpg
    Jun 2015
    17
    the manual says, check parameter and increase the value .
    which parameter is it?
    Jun 2015
    17
    see the attachment for parameter list
    Feb 2006
    338
    You problem probably is not with the loading procedure, but you might review www.tulipmemory.com M100700D - TULIP for Fanuc 6, 11, 12 Manual.pdf where it talks about manually loading the control to make sure.
    Other than that I guess reading thru the 6m paramters manual and reviewing the entries are correct.
    Sorry I can't be of more help with this one.
    Jun 2015
    17
    hello dpuch, i have the manual and also read it. the problem remains, still need to change the parameters.
    i already opend a new post/tread, if somebody has the same machine, so i can view the parameters.
    thanks for the help.
    greetings albert
    Aug 2011
    2517
    are you sure you did the correct procedure to manually change parameters?
    the procedure is....
    Put Parameter Enable Switch ON
    Put Mode Switch to MDI
    Press Function key PARAM
    Type N then parameter number then press INPUT (in this case parameter number typed is 0120)
    Type P then numerical data then press INPUT (type the value you want to put in parameter 0120)
    Put Parameter Enable Switch OFF
    Press Reset.
    does this work on your machine for parameter 0120/0122?
    Jun 2015
    17
    yes, that is way to do it,
    it works for every paramter but not for 0120 and 0122
    Apr 2009
    1379
    fordav, these parameters are not listed in the 6m manual, but are for the 6t-a as max. spindle speed for gear changes.
    Aug 2011
    2517
    yeah I see they are unlisted. he wants 0120 and 0122. no idea why ;-)
    either way the procedure above should work, regardless of the parameter number.
    Jun 2015
    17
    para 120 and 122 are used for tool change i found out, but i could be wrong.
    can somebody help me with solving the problem for this error, and wich parameters are used for this?
    Aug 2011
    2517
    its an old and uncommon machine and I think you are out of luck. your only choice now would be try to contact other owners of the same machine and get a parameter backup.
    try searching for "Fanuc Tape Center Model D" and PM the person who posted. or look wider on the net for other owners of that machine.
    Aug 2011
    2517
    here is one to start you going....
    http://www.cnczone.com/forums/fanuc/...cnc-posts.html
    Jun 2015
    17
    i have found somebody with the same machine,
    where can we find the macro for tool change?
    Aug 2011
    2517
    if there is a tool change macro it will probably be numbered 9000 or higher.
    you need to unlock the 8000 range and/or 9000 range programs by setting parameter 318.7 or 319.7 to 0 then power off/on and you will be able to see all the programs in memory. then just punch out the program you need.
Page 1 of 3 123
  1. Fanuc OT Wear Offset page locked???
    By grumpy74 in forum Fanuc
    Last Post: 02-21-2015, 08:14 AM
  2. System/option parameters locked on ospU10L
    By Zachmuscle in forum Okuma
    Last Post: 10-18-2014, 05:17 AM
  3. Fanuc i18 Locked Read and Ladder
    By mirc899 in forum Fanuc
    Last Post: 09-23-2013, 09:29 PM
  4. Replies: 2
    Last Post: 04-21-2010, 04:28 AM
  5. Replies: 3
    Last Post: 04-01-2009, 11:06 PM
