587,787 active members*
3,213 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > TB 6560 sending voltage to all 3 motors on all 4 pins at once
Results 1 to 10 of 10
    Mar 2015
    3
    Hi Guys, I am stuck trying to get my TB 6560 controller board working with my 3x Nema 23's
    When starting up the TB6560 Without the computer turned on, they were nice, quiet and ready to go.
    But when powered the Controller board with my computer on and plugged in via LPT, the motors would make a bad buzzing/grinding sound.
    It took a while with my limited knowledge, but I found out the motors were moving and checked voltage across the + - to find out they were getting between 0.5 and 3-ish volts, on both the turn and step phases at the same time (on all 3 motors at the same time) :-s.
    I haven't had the motors moving properly yet.
    Could it be the LPT printer cable?
    Anyone else had the same problem?
    Cheers.
    -James.
    (Edit: It might be that the PSU sends power to the motors and the LPT sends signal usually, maybe.
    But the LPT is sending power too)
    Jan 2007
    146
    Re: TB 6560 sending voltage to all 3 motors on all 4 pins at once
    Are you using a laptop? does the board work with lower voltage signal from the laptop LPT . check printer cable with ohm meter or some continuity tester. Make sure all pins are connected straight through: pin 1 - pin 1, pin 2 - pin 2, etc.
    May 2005
    1397
    "my TB 6560 controller board "
    That's the problem right there. Get a better driver board.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Mar 2014
    1132
    I have a 4 axis TB6560 board. I like it actually. It works nice with proper cooling (had to put an extra fan to the regulator).
    Sent from my GT-I9300 using Tapatalk 2
    May 2005
    1397
    It will randomly fail on power up at some (unknown) time in the future. The chip was never designed to be used in this environment.
    Mar 2014
    1132
    You are right. It will fail eventually.
    May 2015
    33
    Q. It is a 3 axis or more, TB6560.?
    Cheers,
    Mark Needham
    PS. I know it is a silly Q. Tell me to pull me head in, if you want to..!
    Mar 2015
    3
    I am very sorry guys, I had to move house shortly after the post and with it all, I forgot which forum I had posted this in.
    Finally found it.
    I am running an old IBM brick (desktop) with 32 bit windows 7.
    I found out the problem was that it was sending constant voltage to more than half of lpt pins at 4.5v, the motors were trying to turn in both directions and step in both too. (wasn't pretty)
    I found that out by hooking up a multimeter into each pin on the printer port on the computer.
    Are they supposed to be sending constant 4.5 volts to that many pins at the same time (maybe there's something in the bios I have to turn off, to stop it sending power to half the pins)
    It's a 3 axis Mark, thanks.
    Sorry for the late reply.
    Mar 2015
    3
    I have the computer set up again.
    I haven't plugged it into the controlled board, I am just getting the voltages off the LPT port from the computer using a multimeter.
    Here it is when I boot up, and also when I have Mach 3 running.
    http://www.cnczone.com/forums/attach...d=294070&stc=1
    The problem I am having now is that when I operate any axis, there is no voltage increase to the pins (Eg. X-Axis is sent to pins 3 and 5) when I hold down the direction and check with a multimeter at the same time.
    Also, if someone knows, are these voltages correct?
    Thank you.
    Edit.
    So I have some progress,
    In the 'Output Signals' I have enabled 'Digit Trig' and 'Enable 1' and set the values to '1'.
    2 of the motors are now making noise, but not turning at all.
    Will keep you guys posted.
    Edit:
    Got 1 spinning, but only in step mode I think, not in jog mode. and that is pretty erratic.
    Jan 2007
    146
    Quote Originally Posted by Sin984 View Post
    [IMG]http://www.cnczone.com/forums/attachment.php
    attachmentid=294070&stc=1[/IMG]
    Thank you.
    Edit.
    Edit:
    the multimeter probably has some dampening so it is hard to see the pins changing state.
    I meant for you to check the printer cable with an ohmmeter. not all cables have a wire for each pin, or are staight through.
    one other thing do not disconect the motor from the drive when powered up.you can brick the drive.
  1. PC sending all parallel pins high when shutting down
    By justinj in forum USB, RS232, PARALLEL etc
    Last Post: 01-14-2015, 10:18 PM
  2. Need help with Ports & Pins - motors not responding and/or not changing direction
    By Keveeee in forum Mach Software (ArtSoft software)
    Last Post: 05-02-2012, 03:52 AM
  3. Voltage & Hot Motors TB6560
    By r00tk1ll in forum CNC Machine Related Electronics
    Last Post: 09-02-2011, 08:17 PM
  4. Is my voltage too high for motors?
    By johnt in forum Stepper Motors / Drives
    Last Post: 12-10-2007, 09:11 PM
  5. Am I sending enough amps to the motors?
    By watsonstudios in forum Automation Technology Products
    Last Post: 07-05-2007, 02:07 PM
