587,830 active members*
2,927 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Got my Fanuc red cap servo motor running!
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Dec 2003
    24220
    Re: Got my Fanuc red cap servo motor running!
    You could also look at adding the Kanalog and use a A-M-C, Copley, Aerotech ±10vdc drives.
    Al.
    Albert E.
  2. #22
    May 2006
    4052
    KFLOP has eight 8-bit PWMs that have 3.3V LVTTL levels that can operate at 65KHz or 32KHz or lower (sorry not 50KHz). See lower right in diagram.
    Regards
    TK
    http://dynomotion.com
  3. #23
    Mar 2004
    369
    Quote Originally Posted by TomKerekes View Post
    Regards
    32 KHz should work fine. 3.3 V will work OK, too, for the PWM signal. But, it appears to have PWM without a direction output. Our servo amps were designed for a sign-magnitude scheme. If used with a PWM where the duty cycle is set for 50% when no motion is desired, the output filters may overheat. That will get worse with higher supply voltage.
    Jon
  4. #24
    May 2006
    4052
    Hi Jon,
    KFLOP can output PWM as sign-magnitude or anti-phase. A small C program is used to output the servo output to the PWM channel. It can handle any conversion, clipping, etc. required for the driver. An extra I/O bit is required for the sign.
    Regards
    TK
  5. #25
    Mar 2004
    369
    Hi Jon,
    Regards
    OK, then, it really ought to work, then!
    Jon
Page 2 of 2 12
  1. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
  2. Servo motor wont stop running
    By cosurfer in forum Servo Motors / Drives
    Last Post: 04-03-2011, 04:50 PM
  3. Help with Fanuc servo motor
    By rmccale in forum Servo Motors / Drives
    Last Post: 01-25-2011, 08:03 PM
  4. Running a Fanuc spindle motor
    By Fudd in forum Uncategorised MetalWorking Machines
    Last Post: 11-11-2006, 04:21 PM
  5. Servo Motor Running away.
    By murphy625 in forum CamSoft Products
    Last Post: 02-27-2005, 08:08 PM
