587,567 active members*
3,906 visitors online*
Results 1 to 6 of 6
    Jan 2012
    Need Help fanuc ot b 601 alarm
    Need Help! Have 601 pmc ram parity error. Have replaced master and pmc boards with reconditoned boards. Still have error. Did reset, delete and error clears but returns when parameter 905 bit 4 is 1 and alarm goes away when bit is 0. Fancu says cabling is not in system. They still think it is hardware. Where??
    Apr 2012
    22
    Re: Need Help fanuc ot b 601 alarm
    Quote Originally Posted by cgccnc View Post
    Dear Friend.
    My CNC alm 601 but i can not clear, can you tell me the means of the parameter 905 bit 4???
    Thanks alot
    Dec 2009
    970
    Quote Originally Posted by vnn34d View Post
    Dear Friend.
    Thanks alot
    905.4 means :PMC MODEL M FUNCTION 12000 STEPS
    Aug 2011
    2517
    its an option telling the control what model the PMC is.
    if you make it 0 the alarm goes away because that tells the machine there is no PMC at all.
    but you will likely get many other errors instead if you try to run the machine without the PMC enabled.....
    Jan 2009
    117
    "Reconditioned" PMC pcb or EPROMS.
    EPROMS may be checked by repetitive reading of the EPROM data with a commercial EPROM writer and confriming the checksum is the same with every read cycle.
    If you have another machine with the same control, swap the PMC pcb to confirm the "reconditioned" quality.
    Feb 2015
    161
    Try 905 bit 3, 2, and 1. ONE at a time and see if it boots. 12000 is the max size for PMC. You might not have that option for that big of a PMC. Try those bits to see when the alarm goes away.
  1. Replies: 2
    Last Post: 11-24-2018, 09:15 PM
  2. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  3. Fanuc 6T-B alarm 402:servo Alarm
    By leiryll in forum Fanuc
    Last Post: 12-03-2013, 08:52 AM
  4. Replies: 0
    Last Post: 08-12-2013, 09:12 AM
  5. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
