587,927 active members*
3,709 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    Feb 2006
    103
    Haas Alarm Problem
    Hi all,
    This is my first post on here and Ive found some very interesting matl. as well.
    But Im currently having a problem with my VMC. (VF-OE)
    I was doing a simple interpolation with a .5" carbide EM (I wasnt working the mill hard either) but i noticed the spindle load was creeping up to 50%. So I waited till the tool was done in the hole and stopped it to look at it. I realized there was a chipped tooth so I decied it was time for another tool. When i went to hit reset and send it home there was 2 alarms 1 was #102 .. servo's are off yada yada and #163 ... Z axis drive fault. Now the spindle is stuck about 9 inches from the table and I have no idea how to relieve this.
    I know on my mill that the Z servo switch can work its self lose after time but I have no way of removing the head cover with the head being down so low. It is hitting on the SHCS that attache the guides of the head.
    So I guess I have 2 questions ... is there a way to relieve the alarm ? and dose it seem logical to remove the guides that run all the way up the colum of the machine so I can remove the SHCS that are in the way of the head ?
    any help would be great .
    Brad
    Jul 2005
    12177
    You should be able to turn the power off and then back on. Do not hit Auto Restart, go into the Settings and find Jog Without Zero Return and turn it on (right arrow I think). Now you should be able to jog your Z axis up. It is a good idea to go to the Current Commands screen so you can see the servo load and make sure you don't try to jog past a hard stop.
    Feb 2006
    103
    yeah I went in today to try that and she stil wont move. I can't move any axis cause with that alarm the servos are still off and will not turn on for any axis to be able to jogged. I contacted Serco Machining (Haas Tech Support) but that will be a week till they get back to me. I have an electrician coming to test the servo motors and grounds. Then go from there.
    Jul 2005
    12177
    Quote Originally Posted by BMackinnon
    It is hitting on the SHCS that attache the guides of the head. Brad
    Are you referring to the cap screws that hold on the bars on either side which retain the sliding way covers? I think you can take them off without anything coming loose except the way covers.
    But based on your descriptions here is something I would try.
    Get a screw jack and put it between the table(vise, whatever) and the end of the spindle. You might need to have a piece of heavy wall tube or something over the cutter.
    You don't give the age of your machine but older Haas have a hydraulic accummulator and cylinder to balance the Z axis weight, later Haas have a magnetic brake on the ballscrew.
    With the hydraulic balance I would just start trying to carefully lift the head with the screw jack.
    With the brake style you need to get power to release the brake. I think you can see the brake on the end of the motor to find out what it needs. It will be DC and probably in the 90 volt region I expect. You might be able to get into the brake directly to give it power or you may have to find the correct wires in the control box. They are fairly easily accessible and I think they are labelled.
    With the jack in place taking a small load and maybe a bunch of pieces of wood placed so it is impossible for the head assembly to drop, apply power to release the brake. I know that if this brake gets power when the servoes are off the Z axis will drop. There should be no reason why you cannot lift it with power applied to the brake.
    In both case you need someone watching the ballscrew to see if it starts backdriving. If you don't see any screw rotation by the time you have put maybe a 1000 lb push on the jack I would say you are hooped but given what I say above about it dropping if not supported I expect you will be able to jack everything up.
    4826
    Brad,
    It might be worth taking a look at the axis drive amplifiers when you have the machine powered on. See if you have some LED's on, or not as an indication that power is getting to the amplifiers.
    History: I used to have the odd spurious fault where I would see an Z axis drive fault alarm, unless I was using the A axis, in which case the fault was the A axis drive fault. It turned out that I had a weak and failing power supply to the drives. Not the main power, but a small standalone one that feeds 12v in there someplace (on a '96 VF3). Anyways, the alarm codes did not really mean what they said, it was simply a case that that power supply had failed, and the Haas interprets the dead amp fault as an amp fault, not as a failure of this little power supply.
    If it is that one, I was able to source an inexpensive exact replacement through Newark electronics.
    Feb 2006
    103
    Yes that is what Im reffering to. I didnt know if it would be a good idea to remove them or not, but it seems like the only way I can lift the head.
    And it is a gas powered counterblance on my Haas not a brake. I thought of jacking it up that way to but didnt know how it would effect the counterblance.
    Quote : It might be worth taking a look at the axis drive amplifiers when you have the machine powered on. See if you have some LED's on, or not as an indication that power is getting to the amplifiers.
    I tryed that too this morning. That was one of the things listed in the service manual and I opened the back turned it on and no lights were visable on the amplifiers that were stated in the schematics of the machine.
    Im assuming and hoping that it is some dumb electrical thing, cause I wasnt under any hard machining and the spindle was only spinning 3200 RPM, like I said I wasnt working it hard at all.
    Jul 2005
    12177
    .....And it is a gas powered counterblance on my Haas not a brake. I thought of jacking it up that way to but didnt know how it would effect the counterblance.......
    It won't; you jacking it up is no different than the ballscrew pulling it up. With the counterbalance jacking is a much more viable option because you are not dealing with as much weight.
    The only way I can imagine running into problems with jacking is if the servo motor is mechanically locked because something has broken. This is not impossible, I just checked alarm 163 in a Haas manual (bedside reading Hu ) and it reads: Current in servo motor beyond limit. Possibly caused by a stalled or overloaded motor. The servos are turned off. This can be caused by running a short distance into a mechanical stop. It can also be caused by a short in the motor or a short of one motor lead to ground.
    4826
    Okay, what sounds a little different about your situation is that the spindle load was showing some sort of load error, which I presume might not have been a real load.
    On my machine, there is a heavy feed wire off the Vector drive which carries the main power to the servo amps, which are all daisy chained together. Check the voltage there, it should be something in the range of 185v DC if I recall correctly.
    Because of the symptom which you reported, there may be an issue with your vector drive, so carefully check the various outputs and see if it is producing voltages for the spindle and the DC bus.
    If you've got that voltage, then the other voltage to check is on the small yellow/white/black twisted coming off the small power supply, going to the servo amps and also is daisy chained, if you can find it. Check those for voltages in the order of 12v, IIRC. Just looking for signs of life in the right places.
    What I was looking at in my VF3 may be somewhat different than what you have on yours.
    Feb 2006
    103
    Thanks Geoff I will try that first thing Monday morning before the electrian comes in.
    and HuFlungDung I will leave and pass all that info to the electrician ... I can wire a car stereo but I dont want my mill to play music so I'll leave that to him and someone more liable.
    On a side note have you ever heard of anyone regrinding thier own spindle ? I was away from the machine and the bosses brother (who dosent even work for the co.) took it upon himself to run the machine and loaded the wrong stock causing a bad crash which resulted in the spinlde being gouged pretty bad. End result I thought I would try my own thing that I thought of awhile ago. I took a die grinder (yes a die grinder ) and mounted it in the vice, dialed it up and programmed the head to run on its own taper. After a lot of working in and a lot of bearing blue ink on the tool holders I was able to gain full coverage on the holder and save the co. approx. $5000.00. There have been a few reps and other guys from other shops come in (we also do custom tooling) and they said they never heard anything like that before. This was about 4 months ago and I noticed I gained a lot of rigidty also from this. I would say about 8% from what I used to run things. When all was done I just had to adjust the toolchanger hieght a little bit and then she ran as smooth as a babys bottom.
    Just wondering if you ever heard of using this method.
    Jul 2005
    12177
    .....On a side note have you ever heard of anyone regrinding thier own spindle......
    I have a healthy heart and get lots exercise so I didn't keel over when I read this "suggestion"; you may be responsible for a few conniptions though.
    I am impressed; did you do this with your Boss' blessing or present it to him as a success when it was done? Although if I was him I would probably have been too occupied slowly strangling the brother to take any notice of what you were doing .
    Mar 2005
    1498
    060617-2044 EST USA
    BMackinnon:
    For in place spindle grinding check out Walt Jr, and Walt III at
    Spindle Grinding Service ( www.spindlegrinding.com ).
    They are experts at this.
    Also see
    http://www.cnczone.com/forums/showthread.php?t=21509
    Nov 2005
    2
    Check to make sure you did not trip a breaker inside the control cabinet, I don't have a VF-0 but on the VF-2 there are 3-4 breakers located above the spindle drive on the power supply card, Be sure to check the one marked solenoid
    Hey its worth a try, this happen to me believe it or not when the light inside the machine shorted out
    Feb 2006
    103
    Quote: did you do this with your Boss' blessing or present it to him as a success when it was done?
    He was there when I did it. We both figured that the machine would be down for at least a week or two and we looked into what it would cost to replace the spindle. So we did it together. We both came to the conculsion that if it didnt work we were gonna have to replace it anyway so it was worth a try.
    The finish of the spindle even looked like it came off a CNC grinder, which you could almost say it did lol. What could of cost upwards of $5000.00 only cost my wages for 4 hours and $15.00 worth of grinder dies.
    Just like our co. slogan "Yeah we can do that "
    No lights on the axis drives means you don't need to perform any mechanical troubleshooting or tasks until that is corrected. I wouldn't remove the first bolt on any covers or jack poop.
    Mar 2006
    19
    I regound one on a fadal years ago, exactly the same way. Keep in mind that they taper is not a straight taper. It is radiused, so the taper on the tool makes contact just at the base, and at the top.
    Sep 2005
    46
    Cad cam Bobcad / ONECNC/ haas
    Gentlemen sorry if I have cut into someones theme.... but being stupid I cant seem to find where to start a new topic...derrrrr
    Anyway im desparate for some guidence.....I have onecnc 2and1/2 D called XR2
    Other than a few idiocincratic glitches it works ok ...but no 3d surface programs...after all it was FREE with the TM2 when it was on promotion over here.....I have spoken to BOBCAD and they are very keen to sell me a package V21 that will do the lathe as well as the mill 3D for under a $1000...with free up grades etc..Thats a fraction of the cost of ONECNC
    ..I ve been playing with a BOBCAD demo and the drawing side seems ok but the toolpath stuff seems messy compared to ONECNC....or is it just that I am acustomed to the onecnc.........so I guess I need some input....what cadcam products are out there that are really worth having.....& yes Geoff I am slowly working on my G code...very slow mate.....
    Get good then get fast...... HELL I just want to get going
    4826
    Gibbs, I thought you had your own cadcam software!
    To start a new topic, go back to the forums topics page and you will see a "New thread" icon a little way down from the top of the page.
    There is a OneCNC or a Bobcad forum to post in.
    Feb 2006
    103
    well I jacked up the head, went with ease. I got the head cover off and the electrician came in and he thinks it is the 12V DC power supply for all axises. That was the only thing that he could find that wasnt giving a reading. So in a few days Ill have a new one and see how it goes from there.
    And werks ... how can a programmed staright line or a taper be radiused. A taper is a straight line between 2 points ... if it is what your are saying then its not a taper at all .. its a simple radius. And I do have full coverage from top to bottom on my tool holders. The visual of the bearing blue when I take the tool out does not lie.
    I honestly have to say I have never heard of anything like that before. Also, when I went to ground the spindle it I never found anything when I was reserching the angle in degrees of a standard milling taper, and I know my toolholders are staright (no rad) Ive checked them before.
    I dont know .. just doesnt seem to make sense to me. Its a taper .. not a rad
    Feb 2006
    103
    The problem is solved.
    We checked our power supply off the machine and it worked fine. Then when backtracking on the machine all that was wrong was a bad plastic covered jumper. Replaced it, ran a few programs and runs fine. Im glad it was some dumb electical probelm and nothing serious.
    Thanks for all the info. it really help alot
    Jun 2006
    22
    Make sure there is no alarm code displayed on the spindle drive wether its a magnatek, mitsubishi or vector. If your axis amp's led doesnt light, your spindle drive might be faulty, that supplies your high voltage to the amps (vector 320v)
    (magnatek or mitsubishi 160v). Also check your low voltage power supply if it's supplying your 12v +5v and -5v to the amps(yellow, black, and white cables on amp).
    If you want to move the head, simply take the 3 screws off from the z axis waycover thats attached to the head, cover will drop down, then hit the e-stop, make sure your counterbalance pressure isn't low however or head will drop, if that was the case it might of sunk down already. Then turn the ballscrew by hand moving the head up or down. Using a jack could cause some serious damage to the machine. Let me know how that works out.
Page 1 of 2 12
