587,517 active members*
3,488 visitors online*
Results 1 to 13 of 13
    Feb 2014
    17
    casters on stand?
    hey everyone, has anyone used caters for the Tormach 1100 stand?
    I'd love some portability as I have limited shop space.
    If anyone has used them and can recommend some caters that would be great.
    Jul 2004
    1424
    Re: casters on stand?
    You want it to be portable, keep a pallet jack parked underneath it. One stroke of the handle, and you can tow it where-ever you want.
    Compare that to leveling casters, where you have to crawl under and rotate each one until the wheel lifts it off. Not anywhere as convenient.
    Tim
    Dec 2010
    1230
    Quote Originally Posted by tmarks11 View Post
    +1
    Leveling casters are a giant PITA.
    Feb 2014
    17
    Great point guys, thanks, much better way to go.
    Apr 2015
    93
    Keep in mind that you will likely have to level and tram up the mill every time you moved it if you wanted to maintain the best accuracy. I would prefer to move the mill with a pallet jack but then you have to store the pallet jack somewhere too.
    Jun 2006
    3063
    A pallet jack is great if you have the room, but I don't so I installed casters like these:
    Foot Master
    with the ratcheting handles which makes it a little easier to raise/lower the mill. The model I bought had a central tapped mounting hole that was the same thread form that is used on the Tormach leveling feet.
    Mike
    Jul 2003
    2
    How well do they work? Is the pad metal or plastic? Do you just screw the foot up in the body to roll?
    Jul 2004
    1424
    Quote Originally Posted by Gilmax View Post
    My pallet jack lives underneath the mill (in the lowered position so the mill feet are on the ground). The handle sticks out maybe 6" from one end of the mill. I never even notice it is there.
ID:	277470Click image for larger version.
    Tim
    Feb 2009
    237
    That seems like an awesome idea! Hope I had seen it 4 years ago. Today, even those two sides are taken. Of course I could reshuffle, but I may need to take some stuff out from the garage. I don't know... Maybe something like the garage door? heh heh heh
    I document my CNC Experience at CNC Dude's Youtube channel. Check it out!
    Jun 2006
    3063
    Quote Originally Posted by shaun View Post
    They work just fine, no problems at all. I wouldn't want to use them on a daily basis but for the few times a year I need to move my mill they are great. The pad that the caster rests on when the wheels are raised off the floor is some sort of dense elastomeric. The ratchets are used to lower the wheel until it raises the mill up high enough to clear the pad. Note that the company (and all reputavble references I've seen) recommend that the casters should be rated so that just two of them can carry the full load.
    Mike
    Dec 2010
    1230
    Intestine caster find! The last picture on that page has an orange dial to adjust the foot up and down which is the style I used on my x3 and on my 12x37 lathe and they are a huge PITA to keep getting a wrench in and over, in and over, in and over. Thr ratchet likely changes the game and makes it MUCH MUCH easier. Don't skimp, but the ratcheting type!
    Apr 2015
    2
    We use air bearings to move very heavy (2 ton) pieces of equipment around. If your shop floor is fairly smooth with no large cracks four round air bearings would do the trick. Hovair is one company that sells them. Basically you attach the shop air hose to the quick connect line and push the equipment around in any direction with almost no resistance. The only caution is due to the low friction it is very easy to get it moving, but you have momentum working against you when trying to stop it quickly.
    Mar 2006
    15
    +1 on the pallet jack. It sits on the coolant tank side if the machine. Just about everything else in the shop is on casters including work benches so it's easy to roll everything out of the way and then move the pallet jack. My location is marked so putting it back doesn't cause any issues.
  1. Help with Casters?
    By fretsman in forum Want To Buy...Need help!
    Last Post: 06-14-2011, 09:47 AM
  2. machine casters
    By jmush24 in forum Shopsabre
    Last Post: 02-18-2011, 12:06 AM
  3. New Machine Casters
    By PhillyCyberJoe in forum Joes CNC Model 2006
    Last Post: 03-14-2009, 02:43 AM
  4. Casters on Tormach Deluxe stand
    By apeman88 in forum Tormach Personal CNC Mill
    Last Post: 01-04-2008, 02:46 AM
  5. air casters
    By jack clay in forum Mechanical Calculations/Engineering Design
    Last Post: 05-01-2007, 04:51 AM
