587,699 active members*
3,613 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Lifting bar links look a little thin?
Results 1 to 12 of 12
    Apr 2015
    93
    Hi, I just received my lifting bar from Tormach and the links seem a little "wimpy y. " Perhaps they are normal. What do you guys think?
    May 2010
    327
    Re: Lifting bar links look a little thin?
    Maybe - I remember thinking they looked a bit on the weak side with the Tormach I helped move last fall, but they worked fine.
    McMaster has a nice selection of shackles - and with them - they're work load rating if it helps ease your mind at all. They're surprisingly strong.
    McMaster-Carr
    WW
    Manufacturing & Development
    ThermaeCooling.com
    Oct 2010
    136
    They look the same as the ones I have.
    I ended up buying an expensive shackle and hook with a swivel to hang mine on due to the complexities involved in my installation. It wasn't impressive looking either and it was rated for 8,000 pounds I think? Bought from McMaster.
    Dec 2007
    379
    Mistake post
    Sep 2010
    122
    While I used my own lifting concoction I had these similar thoughts in an earlier post:
    "Eye Bolt mounted to T slot (1/2" nut and washer slide right in). Notice the China on chain! I get a little leery, Chinese lift, Chinese chain, Chinese hooks, Chinese bolts ..."
    Attachment 276122
    Apr 2015
    93
    Just to update. I had no issues getting the mill on the stand. They are obviously designed to handle the load required. However, I cant imagine it would cost much more to include thicker ones and I'm sure many people would be willing to pay a little extra for a much higher margin of safety.
    Sep 2009
    624
    Quote Originally Posted by Beezle View Post
    Cheapest steel I can find (A36) claims roughly 48 kpsi tensile strength for 1" bar. The chain I got from Tormach (years ago) mikes 0.320" diameter, and the bar is about 0.460, so on an area basis the Tormach chain I have should handle around 5 kpsi if it's just merchant steel (as long as it's properly welded, of course). The chain appears more than adequate to handle the load, plus a more than adequate margin of safety. I'd worry (a lot) more about dangling a 3/4 ton weight on a single point lift.
    Jan 2013
    97
    Quote Originally Posted by inov8r View Post
    You forgot Chinese mill...
    Feb 2015
    30
    Well I've just used the lifting bar and all the parts that go with it today. worked like a treat. and that was with an engine crane on the 250kg rate mark.. oops :P
    Sep 2010
    122
    Quote Originally Posted by Philbobb View Post
    Haha yes! Yes I did.
    Jul 2004
    1424
    I lifted mine by using a 1" bar through the lifting holes on the front of the mill base. Seemed like a better idea than putting all that stress on the mill table. Using a load spreader, it was easy to precisely balance the mill so it was perfectly horizontal prior to lowering onto the base.
    Attachment 276544
    Tim
    May 2013
    455
    Quote Originally Posted by tmarks11 View Post
    Attachment 276544
    I'd love to see this pic, the attachment is a dead link, any chance you can reload it or PM me the pic?
  1. Lifting Bar Size?
    By Peter Neill in forum Tormach Personal CNC Mill
    Last Post: 09-10-2012, 02:45 PM
  2. G0602 lifting?
    By thewoodnerd in forum Benchtop Machines
    Last Post: 10-18-2011, 04:05 AM
  3. Lifting the beast
    By cyclestart in forum Benchtop Machines
    Last Post: 04-03-2011, 03:50 PM
  4. z axes lifting
    By John Teichman in forum Mach Mill
    Last Post: 02-11-2008, 04:12 AM
