Alott of Routers also have Drill blocking and sawing option that are not on a CNC Mill.
Cadcam
Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
But then they call them point to point machining centers.Originally Posted by cadcam
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
Which I can never understand because I have a bunch of VMC's which are normally called milling machines. In absolute mode they interpret a G-code command to mean 'start from the point you are at and move to that other point defined by these coordinates'. In incremental mode they interpret a G-code command to mean 'start from the point you are at and move this distance on the Y axis and this distance on the X axis to that other point'.Originally Posted by ger21
So clearly they are point to point machines.
What's your point?Originally Posted by Geof
Consistency is a good thing....unless you're consistently an idiot.
