Hello Hoss,
Thank you for the great reply. Most of the mods on the mill I am buying are from your plans. I would like to also add the automatic drawbar to be able to also then add the tool holder or tool changer. My question is that the link you sent me has plans for a drawbar that works with a cam lever and I have also seen versions on your site that are direct. its tough to know which is the best version or the most recent since you have many versions. For my needs which of your drawbar designs is the best? Also I noticed that the tool holder just drops the tools in rather then sliding in from the side like the ATC. My guess id since it does not need to rotate then the delrin clips are not needed. Thus it seems I can buy the cheaper TTS tool holders on ebay withouut the clip groove. However, I am not opposed to upgrading to one of your motorized TTS designs. Can I get some pros and cons on how you liekd the static version over the rotary?
Thanks again,
Marc
