After a "Check System Label: Error" message, you must enter '99' and press the INPUT key.
It will ask the question "# axes?", you enter the # of controlled axes, probably 2 unless you have a C-axis ( the spindle is normally not considered an axis) and then you will have to enter the options in hexadecimal. Do you have a parameter list?
