587,409 active members*
3,289 visitors online*
Page 9 of 10 78910
Results 161 to 180 of 199
  1. #161
    Jul 2013
    85
    Quote Originally Posted by dmauch View Post
    You don't have to assume that Mach3 is reading that line of code's feed rate as inches/MM per minute. It is but that is where G93 would control the AC axis in degrees per minute
    That's not what I meant. I thought maybe the xyz move as in sqrt( x^2 + y^2 + z^2 ) was dictating the speed of rotary motion. I still think the way it's mixing the motion is messed up.
    Maybe g93 works for head head by setting offsets? But at the moment it doesn't make sense to me what it's doing with the fword.
  2. #162
    Jul 2013
    85
    http://www.machsupport.com/forum/index.php?topic=10104.0;wap2
    Ah. That's why.
  3. #163
    Jan 2006
    758
    Re: DIY Hobby Size 5-axis mill
    Quote Originally Posted by MichaelGolden View Post
    Ah. That's why.
    Hi there Micheal,
    This is definitive answer I needed.... thnks for that...
    also Re:
    "Dan:
    As I recall, it was some time after Rab’s fix was done that G93 was implemented..afaik it was implemented well and works fine in m3.
    Art"
    Rab did mention to me that it was some time ago that he last looked at this..... However, from Micheal's found info it would seem that for rotary use.. the 'fix' he came up with at the time.. remains the most usable / useful....
    This is not to say I won't include the option for g93... at some point the Mach 3 bug will be fixed...
    TTFN
    Danny
    What one man can do another man can do..
    BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org
  4. #164
    Aug 2013
    16
    Quote Originally Posted by yohudi View Post
    Hi there Micheal,
    also Re:
    "Dan:
    Art"
    TTFN
    Danny
    I don't understand why people are having problems with Mach3 as far as g93 goes, it works fine for me.
    The real problem I am having with ver 107 toolkit is that it is outputting two F word per line in some spots
    and Mach3 does not like this. Below is some 5 axis gcode that I generated with a commercial CAM package
    and seems to run fine with Mach3.
    N1 G00 G17 G40 G49 G90 G94 A0 B0
    N2 T1
    N3 M06
    N4 S0 M03
    N5 G54
    N6 G0 X3.046 Y-.914 A0. C0.
    N7 G43 Z2. H0 M09
    N8 Z2.262
    N9 X-.155 Y-2.62 A16.986 C-76.086
    N10 G1 Z2.162 F2.5
    N11 G93 X-.09 Y-2.489 Z2.139 A16.468 C-75.556 F31.8
    N12 X-.045 Y-2.393 Z2.123 A16.066 C-75.023 F43.8
    N13 X-.033 Y-2.356 Z2.117 A15.921 C-74.914 F115.8
    N14 X.001 Y-2.259 Z2.102 A15.528 C-74.417 F44.1
    N15 X.01 Y-2.232 Z2.096 A15.397 C-74.283 F154.8
    N16 X.052 Y-2.107 Z2.073 A14.782 C-73.506 F33.7
    N17 X.061 Y-2.064 Z2.065 A14.558 C-73.338 F96.3
    N18 X.085 Y-1.952 Z2.045 A13.979 C-72.788 F37.5
    N19 X.097 Y-1.893 Z2.032 A13.612 C-72.498 F68.7
    N20 X.115 Y-1.803 Z2.014 A13.053 C-71.9 F45.3
    N21 X.125 Y-1.737 Z2.001 A12.638 C-71.532 F61.8
    N22 X.138 Y-1.648 Z1.985 A12.086 C-70.863 F45.9
    N23 X.143 Y-1.571 Z1.973 A11.687 C-70.441 F54.8
    N24 X.148 Y-1.519 Z1.965 A11.388 C-70.035 F79.6
    N25 X.153 Y-1.487 Z1.959 A11.181 C-69.704 F126.1
    N26 X.161 Y-1.38 Z1.942 A10.494 C-68.697 F38.1
    N27 X.163 Y-1.358 Z1.938 A10.356 C-68.477 F186.4
    N28 X.166 Y-1.326 Z1.933 A10.15 C-68.074 F126.3
    N29 X.17 Y-1.206 Z1.915 A9.365 C-66.647 F33.7
    N30 X.173 Y-1.154 Z1.908 A9.019 C-65.803 F76.7
    N31 X.177 Y-1.041 Z1.892 A8.272 C-63.752 F35.6
    N32 X.18 Y-.992 Z1.887 A7.961 C-62.594 F81.9
    N33 Y-.93 Z1.879 A7.561 C-61.119 F64.2
    N34 Y-.911 Z1.877 A7.435 C-60.617 F205.8
    N35 Y-.817 Z1.867 A6.857 C-57.581 F41.8
    N36 X.179 Y-.792 Z1.865 A6.711 C-56.712 F158.8
    N37 Y-.742 Z1.86 A6.423 C-54.578 F76.5
    N38 X.18 Y-.705 Z1.857 A6.19 C-52.676 F100.7
    N39 X.181 Y-.637 Z1.851 A5.801 C-48.494 F53.9
    N40 X.178 Y-.587 Z1.847 A5.553 C-44.714 F67.9
    N41 X.177 Y-.578 A5.51 C-43.983 F380.3
    N42 X.17 Y-.527 Z1.843 A5.318 C-38.753 F59.1
    N43 X.166 Y-.507 Z1.842 A5.271 C-36.19 F130.4
    N44 X.159 Y-.486 Z1.841 A5.255 C-32.942 F106.2
    N45 X.153 Y-.472 C-30.414 F138.5
    N46 X.137 Y-.451 Z1.84 A5.346 C-25.056 F65.7
    N47 X.13 Y-.446 A5.415 C-22.908 F159.9
    N48 X.125 Y-.444 Z1.841 A5.484 C-21.388 F222.2
    N49 X.114 Y-.443 A5.638 C-18.383 F109.8
    N50 X.103 Y-.448 Z1.842 A5.834 C-15.717 F114.4
    N51 X.088 Y-.46 Z1.844 A6.152 C-12.54 F85.3
    N52 X.086 Y-.464 Z1.845 A6.231 C-11.699 F344.
    N53 X.076 Y-.487 Z1.848 A6.684 C-8.077 F71.9
    N54 X.072 Y-.503 Z1.85 A6.954 C-6.494 F137.6
    N55 X.066 Y-.517 Z1.852 A7.165 C-5.578 F172.6
    N56 X.063 Y-.523 A7.238 C-5.576 F552.8
    N57 X.065 Y-.524 Z1.853 A7.269 C-5.575 F1485.5
    N58 X.069 Y-.527 A7.286 C-5.95 F545.3
    N59 X.089 Y-.536 A7.327 C-8.157 F99.1
    N60 X.102 Y-.541 Z1.854 A7.343 C-9.7 F145.7
    N61 X.141 Y-.569 Z1.855 A7.392 C-14.744 F44.8
    N62 X.143 A7.379 C-15.067 F731.3
    N63 X.147 Y-.564 A7.244 C-16.002 F234.6
    N64 X.15 Y-.558 Z1.853 A7.104 C-17.195 F210.4
    N65 X.157 Y-.553 Z1.852 A6.857 C-20.186 F94.1
    N66 X.165 Y-.556 Z1.851 A6.669 C-23.748 F85.9
    N67 X.17 Y-.56 A6.607 C-25.158 F208.3
    N68 X.182 Y-.576 A6.502 C-28.973 F77.1
    N69 X.194 Y-.604 Z1.853 A6.481 C-33.033 F70.7
    N70 X.197 Y-.614 A6.497 C-34.168 F243.3
    N71 X.205 Y-.643 Z1.855 A6.556 C-37.188 F88.7
    N72 X.21 Y-.67 Z1.857 A6.644 C-39.51 F107.5
    N73 X.216 Y-.71 Z1.86 A6.803 C-42.372 F79.8
    N74 X.219 Y-.731 Z1.862 A6.9 C-43.668 F158.3
    N75 Y-.747 Z1.864 A6.986 C-44.725 F209.
    N76 X.224 Y-.835 Z1.872 A7.459 C-49.151 F41.1
    N77 X.231 Y-.899 Z1.879 A7.786 C-51.459 F59.
    N78 Y-.91 Z1.88 A7.848 C-51.892 F348.5
    N79 Y-1.042 Z1.894 A8.602 C-56.039 F29.8
    N80 Y-1.068 Z1.898 A8.755 C-56.693 F154.9
    N81 X.23 Y-1.1 Z1.902 A8.941 C-57.536 F123.8
    N82 X.227 Y-1.146 Z1.907 A9.205 C-58.665 F87.8
    N83 X.222 Y-1.238 Z1.92 A9.754 C-60.574 F44.
    N84 X.215 Y-1.295 Z1.928 A10.086 C-61.738 F71.8
    N85 X.212 Y-1.326 Z1.933 A10.269 C-62.298 F132.9
    N86 X.205 Y-1.406 Z1.945 A10.755 C-63.574 F51.
    N87 X.194 Y-1.487 Z1.958 A11.242 C-64.869 F50.6
    N88 X.182 Y-1.573 Z1.973 A11.767 C-66.109 F47.4
    N89 X.175 Y-1.621 Z1.98 A12.018 C-66.743 F87.9
    N90 X.161 Y-1.71 Z1.994 A12.49 C-67.783 F46.9
    N91 X.157 Y-1.742 Z2. A12.664 C-68.094 F129.2
    N92 X.136 Y-1.825 Z2.016 A13.157 C-69.075 F49.8
    N93 X.132 Y-1.844 Z2.019 A13.269 C-69.267 F220.
    N94 X.12 Y-1.902 Z2.031 A13.625 C-69.773 F70.3
    N95 X.084 Y-2.063 Z2.06 A14.452 C-71.072 F26.2
    N96 X.083 Y-2.067 Z2.061 A14.473 C-71.115 F1070.7
    N97 X.062 Y-2.128 Z2.072 A14.772 C-71.663 F69.9
    N98 X.03 Y-2.222 Z2.09 A15.243 C-72.477 F44.7
    N99 X.017 Y-2.257 Z2.096 A15.388 C-72.775 F123.7
    N100 X-.034 Y-2.399 Z2.119 A15.963 C-73.765 F30.4
    N101 X-.039 Y-2.412 Z2.121 A16.012 C-73.841 F343.2
    N102 X-.081 Y-2.485 Z2.134 A16.327 C-74.59 F57.7
    N103 X-.129 Y-2.577 Z2.151 A16.736 C-75.356 F45.7
    N104 X-.157 Y-2.629 Z2.162 A16.982 C-75.843 F79.5
    N105 X-.178 Y-2.662 Z2.168 A17.111 C-76.206 F128.8
    N106 X-.182 Y-2.668 Z2.169 A17.134 C-76.28 F733.7
    N107 X-.178 Y-2.661 Z2.168 A17.119 C-76.285 F613.4
    N108 X-.155 Y-2.62 Z2.162 A16.986 C-76.086 F102.4
    N109 G0 Z2.835
  5. #165
    Jan 2006
    758
    Quote Originally Posted by billw999 View Post
    Hi There,
    My only problem with g93 and Mach 3 is weather or not to go for a direct implementation of trunnion 1.07 .. or to go with the pre-g93 version...
    that's it.. don't use trunnion myself.. or g93....
    Any rotary axis work I've done with CNC_Toolkit has worked pretty much fine withoutg93 However, I am not scripting for myself at the moment.. or my own use... so if it's generally felt to be a useful feature then I want to include it.... unless it's more trouble than it's worth....
    TTFN
    Danny
  6. #166
    Jul 2013
    85
    Hi There,
    TTFN
    Danny
    For me, the feedrate is the biggest issue. I broke an endmill the first time using G94 because as the toolpath changed it ramped up in speed when I did not expect it. Now before every run I sit by the program for an hour manually changing the feedrate each few lines. Its a real pain.
    I am using an older version of mach3. Its an old computer dedicated to the mill without internet access. I'll have to try the newer version.
  7. #167
    Jul 2013
    85
    N2 T1
    N3 M06
    N4 S0 M03
    N5 G54
    N7 G43 Z2. H0 M09
    N8 Z2.262
    N10 G1 Z2.162 F2.5
    N109 G0 Z2.835
    Try this one and let me know what you think.
    ( Output Starts Here )
    (File:xyzac.gmax)
    (Toolpath:Projected01)
    T1M6
    M3
    G93 (Feedrate 100.0)
    N2 X0.0053 Y-2.4643 Z4.768 A-51.8114 C156.971 F18.6319
    N3 G1 F50.0 X0.0053 Y-2.4643 Z2.768 A-51.8114 C156.971 F50.0
    N4 G1 F100.0 X0.0061 Y-2.1318 Z3.1295 A-42.7823 C152.891 F719.168
    N5 X0.0066 Y-1.8069 Z3.3919 A-35.1233 C147.313 F822.696
    N6 X0.0068 Y-1.5217 Z3.5725 A-28.8681 C139.386 F896.744
    N7 X0.0071 Y-1.2614 Z3.7008 A-23.5395 C127.665 F948.494
    N8 X0.0072 Y-1.0949 Z3.7696 A-20.1415 C110.684 F981.564
    N9 X0.0069 Y-0.7992 Z3.8634 A-14.3245 C122.047 F970.345
    N10 X0.0068 Y-1.034 Z3.7918 A-18.9256 C141.837 F982.67
    N11 X0.007 Y-1.3202 Z3.6745 A-24.7189 C152.382 F951.634
    N12 X0.0066 Y-1.6509 Z3.4961 A-31.6521 C158.642 F903.222
    N13 X0.0062 Y-1.9996 Z3.246 A-39.535 C162.671 F834.331
    N14 X0.0055 Y-2.3513 Z2.9046 A-48.5486 C165.489 F739.028
    N15 X0.0055 Y-2.2882 Z2.9731 A-46.851 C174.715 F984.848
    N16 X0.0062 Y-1.9268 Z3.3042 A-37.8286 C173.589 F747.913
    N17 X0.0065 Y-1.567 Z3.5467 A-29.8351 C171.964 F839.594
    N18 X0.0069 Y-1.2107 Z3.723 A-22.5002 C169.278 F906.167
    N19 X0.0064 Y-0.8889 Z3.8386 A-16.0666 C164.29 F953.066
    N20 X0.0048 Y-0.5169 Z3.9209 A-9.1574 C151.432 F983.175
    N21 X0.0047 Y-0.5161 Z3.921 A-9.1444 C203.631 F1000.0
    N22 X0.0065 Y-0.8882 Z3.8387 A-16.0551 C192.064 F983.176
    N23 X0.0071 Y-1.2104 Z3.7231 A-22.4951 C188.037 F953.069
    N24 X0.0065 Y-1.5667 Z3.5469 A-29.8293 C186.135 F906.171
    N25 X0.006 Y-1.9266 Z3.3043 A-37.8257 C184.979 F839.603
    N26 X0.0054 Y-2.2881 Z2.9733 A-46.8471 C184.22 F747.929
    N27 X0.005 Y-2.3508 Z2.9051 A-48.5367 C193.509 F984.96
    N28 X0.0057 Y-1.9992 Z3.2463 A-39.5262 C195.99 F739.077
    N29 X0.0065 Y-1.6503 Z3.4964 A-31.6392 C199.56 F834.363
    N30 X0.0069 Y-1.3194 Z3.6749 A-24.7042 C205.201 F903.237
    N31 X0.0059 Y-1.0334 Z3.792 A-18.9141 C215.197 F951.643
    N32 X0.0067 Y-0.7983 Z3.8636 A-14.3071 C233.591 F982.673
    N33 X0.0069 Y-1.0937 Z3.7701 A-20.1193 C246.289 F970.454
    N34 X0.0071 Y-1.2604 Z3.7013 A-23.5183 C229.76 F981.57
    N35 X0.0063 Y-1.5208 Z3.573 A-28.8499 C218.667 F948.509
    N36 X0.0063 Y-1.8063 Z3.3924 A-35.109 C211.082 F896.776
    N37 X0.0054 Y-2.1313 Z3.13 A-42.7687 C205.896 F822.753
    N38 X0.0046 Y-2.4637 Z2.7687 A-51.7947 C202.125 F719.266
    N40 G0 X0.0046 Y-2.4637 Z4.7687 A-51.7948 C202.125 F50.0
    M5
    M30
    Yeah the double feedrate is just because I wasn't sure how to go about changing that in the post yet. You must also be careful not to forget to remove the first and last line with x0 y0 z0 and any lines with an F0.0 number.
  8. #168
    Aug 2013
    16
    Lines three and four still have two F words per line
  9. #169
    Jul 2013
    85
    Yeah oops. I quickly generated that one. It's the file I was testing yesterday. Just remove the first extra fword in the line.
  10. #170
    Aug 2013
    16
    It runs without any problems that I can see.
    For anyone trying to generate toolpaths with Gmax and cnctoolkit there are a couple of things that I could find no mention of
    in the manual, one the surface you are projecting the splines onto need to be above the 0 plane, and second the imported DXF
    file that you are projecting needs to be subdivided or it will not lay on the surface right.
  11. #171
    Jan 2006
    758
    Hi There,
    " the surface you are projecting the splines onto need to be above the 0 plane"....
    NOT true.... as long as the spline for projection is above the mesh then you can project just fine... I've just tested it now to be 110% sure...
    " the imported DXFfile that you are projecting needs to be subdivided"
    The advice in respect of appropriate subdivision in my ebook applies to ALL shapes.. and is stated as doing so quite plainly.... so I would think that an imported shape is just another type of shape.. and doesn't need any special advice.... it's a shape... treat it like one...
    Hope this helps
    Danny
  12. #172
    Aug 2013
    16
    Hi There,
    Hope this helps
    Danny
    you can project the splines but when you generate the toolpath it does not stay normal to the surface unless you are above 0.
  13. #173
    Aug 2013
    16
    This shows the results I get above and below 0.
    Attachment 274272
    Attachment 274274
  14. #174
    Jan 2006
    758
    UTTER RUBBISH....
    by 'doesn't stay normal to the surface' I take it you mean... incorrect angle vectors when the toolpath is generated....
    You are below the origin... so 'angle round origin' will obviously not produce correct vectors... but this has absolutely NOTHING to do with PROJECTION... just means you didn't think about the toolpath angle options... before you made the toolpath... other settings WILL produce usable angle vectors....
    This basic problem / issue / misunderstanding.... show's me you are missing some fairly important info / appreciation of the basic principles... re: toolpathing with CNC_Toolkit....
    TTFN
    Danny
  15. #175
    Aug 2013
    16
    If I used Angle from origin what you said would make sense, but I used Angle from Reference surface.
  16. #176
    Jan 2006
    758
    Hi There,
    again.. this is what I mean.. about missing something important...
    Angle round reference surface is very much dependant on the surface... the level of sub-division.. AND the location in the scene..... If incorrectly located.. angle from reference surface will pretty much always give incorrect vectors...
    BUT... This has absolutely NOTHING to do with projection...
    It's about understanding how CNC_Toolkit derives and processes vectors BEFORE hitting make toolpath.
    TTFN
    Danny
  17. #177
    Jan 2006
    758
    Perhaps I should be a little clearer...
    You can project anywhere in the scene... as long as the spline overlays the object.. and you're selected projection method is appropriate...
    Angle vectors are not involved at this point.....
    You can then locate the spline / object anywhere you like in the scene... and process the spline to toolpath... depending on scene location... different options produce different results... even when you might think otherwise...
    Angle processing does not come into play.. until you press make toolpath... at which point cnc_toolkit attempts to calculate angles to suit the selected option... however if scene location does not suit your selected option.. the vectors you get will not be suitable... even IF you use angle round reference surface....
    Hope this helps
    Danny
  18. #178
    Aug 2013
    16
    Hi There,
    TTFN
    Danny
    I am not trying to say it has anything to do with projection, at first I had two separate problems, one my imported
    splines would project below the reference surface, and second the angle vectors were not normal to the surface.
    I subdivided the splines and that took care of the projection problem. Now I am trying to figure out the angle control.
    You are right I am missing some thing important but you getting all excited and capping me is no help. I will go
    back and look at the pdf again
  19. #179
    Jan 2006
    758
    You are right I am missing some thing important but you getting all excited and capping me is no help........I will go
    Hi There,
    I am not 'excited, and 'capping' you' ??? .
    My only concern is that if you say something is ommitted.. from MY ebook....it is in fact omitted.... I do believe I have some right of reply....
    AND to ensure info in respect of CNC_toolkit in this thread is correct....
    TTFN
    Danny
  20. #180
    Aug 2013
    16
    Hi There,
    TTFN
    Danny
    Some people take all caps to be the equivalent of yelling.
    You have every right to set the record strait as far as omissions go, I admit I missed some things
    in the manual and didn't understand the rest, and still don't, I just thought others might be having
    the same problems as me and was trying to help. Maybe I am the only one who is having trouble.
Page 9 of 10 78910
  1. Hobby mill with cnc conversion
    By shibby_cbs in forum Want To Buy...Need help!
    Last Post: 09-02-2011, 07:24 PM
  2. 5 Axis CNC Hobby Router / Mill?
    By antonzedd in forum Canadian Club House
    Last Post: 04-24-2010, 11:56 AM
  3. Would this indexable end mill be a bad purchase for a hobby mill?
    By Oldmanandhistoy in forum MetalWork Discussion
    Last Post: 03-10-2008, 03:20 PM
  4. Looking for Hobby Size Vacuum Form Service
    By Mark30504 in forum Vacuum forming, Thermoforming etc
    Last Post: 03-25-2007, 03:14 PM
