587,126 active members*
2,984 visitors online*
Results 1 to 2 of 2
    laser cut engrave 3.3 issue
    Last year i bought 2 x STORM 500 laser engraving machines from WKLASER and have been very impressed with the machines in general for the money paid. i have previously purchased an LC6090 from WKLASER 7 years ago and is still running like a dream (ok have changed lots of bits) but has cherned out a lot of work during this time.
    Anyway, i have a really annoying issue with the software on the STORM500 machines in that when i type any text into the text edit box such as 'TEST TEST TEST' what is then laid onto the screen is'TESTTESTTEST' with no spaces...
    Have spent a lot of time asking WKLASER what is going on as this does not happen with lasercut 5.3 on my LC6090 but they are saying this is normal.. which obviously cannot be as the software is designed as it is a major pain.
    Also, i cannot rotate any imported artwork (.bmp) which is not the end of the world but can be annoying.
    Has anyone else come across these issue's???
    Much apprecaite any replies as i want to purchase more machines from WKLASER but will not until this issue is resolved.
    Many Thanks
    Mar 2015
    40
    Re: laser cut engrave 3.3 issue
    this probably needs to be in proper forum section for you to get more meaningfull replies.
    i do own a storm500 as well for three weeks now and use the same very software as well. used PHCAD on my previous machine which is quite similar. I find those editors very limited so all the text and all the actual drawing i do in autoCAD and only use laser software to import the DXF and set power for layers. so my suggestion is to use a better editor, there are open source CAD programs out there if budget is a consern. even MS visio (it can save in DXF) is a better editor .
  1. 40K laser slow to engrave. HELP!
    By 6345789 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-13-2014, 11:37 AM
  2. Material to cut / engrave in my new laser
    By herrmc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-15-2012, 04:57 PM
  3. I need a laser engrave
    By flinstone in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-21-2011, 06:57 AM
  4. How to engrave pcb with laser
    By codes in forum Uncategorised MetalWorking Machines
    Last Post: 03-17-2008, 09:23 PM
  5. Need laser to engrave photos
    By aerialpixs in forum Engraving Machines
    Last Post: 12-18-2007, 05:34 AM
