587,147 active members*
5,610 visitors online*
Results 1 to 4 of 4
    Aug 2011
    135
    What kind of tap to use
    Just getting into a haas smm2 and need some advice. Never was able to rigid tap in my current machine. I have a large job waiting to go as soon as the machine is here and running. I need to tap about 12k holes. Materials are mostly aluminum, but there will be some copper and titanium.
    8-32 through hole .125 thick
    I have been told over and over that form are the strongest, but I don't have any experience with them, and don't have the time to experiment
    Any advice is appreciated
    Sent from my SM-G900V using Tapatalk
    Aug 2011
    135
    Re: What kind of tap to use
    One other note is that as part of the fixturing of this job after the holes are tapped I need to take the pallet off the table and put screws through the back side of the pallet before the final operations, so my assumption is a tapper tap will give me a bunch of chips in the clearance hole in the fixture that would slow down progress. So I'm assuming I need to be looking at spiral flute or form
    Jun 2004
    6618
    I use spiral point taps (gun taps) most often for through holes, especially if you have clearance for chips underneath like in a vise. They work great and last a long time. Months and thousands of holes in aluminum and mild steel. Cheap too.
    However I do tap some steel that is pretty thin. .090" thick or 13 gage CRS. I use form taps in that material. They are more expensive and put a burr on the bottom side, but that gives the screw more to bite into. It makes no chips either, but the taps are more expensive.
    Form taps will probably be your best bet for getting the most thread out of thin material and they last too.
    Lee
    Mar 2010
    1852
    One other thing to consider is that with the form tap, because it pushes the metal out to form the thread, it will leave a burr or rise in the plate on both sides. I use form taps a lot, but they work better when you can chamfer the hole before tapping and for holes that don't go through for the same reason.
    You mention removing threading chips, but you will also have drilling chips.
    Mike
  1. What kind of cmm would you buy?
    By joecnc1234 in forum Polls
    Last Post: 09-24-2015, 08:03 AM
  2. Two of a kind - almost.
    By cncadmin in forum EnRoute
    Last Post: 12-18-2011, 10:00 PM
  3. RFQ: Custom Dog Tag (kind of an odd job...)
    By scl23enn4m3 in forum RFQ (Request for Quote)
    Last Post: 07-31-2011, 03:54 AM
  4. What kind of postprocessor?
    By Klank in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-07-2010, 10:50 PM
  5. What Kind Of CMM?
    By ajl6549 in forum Calibration / Measurement
    Last Post: 03-01-2007, 06:57 PM
