587,333 active members*
3,754 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X2 mini mill head dimensions
Results 1 to 6 of 6
    Jan 2005
    1943
    I am working on a new project and am thinking about using an X2 head that can be purchased from Little Machine Shop. What I need to know are the dimensions of the head. I have attached a picture of the dimensions I need which are as follows.
    A - Width of head casting
    B - Height of Head Casting
    C - Depth of head casting
    D - Distance from rear of casting to spindle centerline
    EDIT - I would also like the distance the spindle nose protrudes below the bottom of the casting.
    I don't need exact measurements. Just a tape measure accuracy is good enough for what I need right now.
    Thanks in advance.
    John B.
    Jul 2004
    218
    Re: X2 mini mill head dimensions
    A - 3.47"
    B - 4.35"
    C - 5.27"
    Jan 2005
    1943
    Thanks.
    Would anyone have the other 2 dimensions?
    E - distance the spindle nose protrudes below the bottom of the casting.
    Thanks again.
    John B.
    Mar 2004
    636
    This drawing might help.
    Spindle Drawing
    Dan
    Check out what I am working on at www.routerbitz.com!
    Apr 2008
    61
    I was going to make a mill with a head like that too. I bought a mini lathe head off eBay. Since buying it, I have since been given a different headstock assembly. If you could use a MT3 spindle headstock I can make you a good deal on it.
    Sent from my iPad using Tapatalk
    Harbor Freight X2
Name:	x2 head layout dimensioned.jpg
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  1. X2 Mill head dimensions
    By cnctube in forum Benchtop Machines
    Last Post: 07-18-2011, 09:59 AM
  2. X2 mini mill head from little machineshop
    By FandZ in forum DIY CNC Router Table Machines
    Last Post: 05-09-2010, 07:09 PM
  3. Hot Head on Mini Mill
    By Me2 in forum Taig Mills / Lathes
    Last Post: 12-26-2009, 04:48 AM
  4. Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head
    By fignoggle in forum Benchtop Machines
    Last Post: 05-12-2009, 05:11 AM
  5. Mini Mill Head Height
    By dropride in forum Benchtop Machines
    Last Post: 12-04-2005, 12:39 AM
