I just purchased a 1998 BMC 3017 with the SSM control. I'm familiar with hurco conversational programming from running one 15++ years ago. I'm 65 and semi-retired from being self employed, but I still work for kicks and grins and to make extra money. Now, the one thing that I can't remember on programming the hurco is how to set the side cutting depth on an end mill. I'm programming a outside frame on a part (4140 steel) with approx .400 stock on each side . I want to take about .125 depth of cut on the xy axis. Hogging mill, I'm old school. Z depth and peck depth is no problem. I know it's in the parameters somewhere but I can't find which one. The only one that seems like it applies is in the milling parameters on pocket overlap %. Tried changing it and nothing happened. Can someone explain to me in plain english where I need to go for this setting. I know that I can change the tool diameter and achieve the same thing, but then I have to rerun the program each time I change the tool diameter.
