587,584 active members*
3,753 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Need sketchup.rb file for SketchUp v7
Results 1 to 5 of 5
    Apr 2009
    39
    I'm running SketchUp v7 on old hardware with Mac OSX 10.6 and just found a plugin that I want to use which is written as a ruby script. However it requires another file called sketchup.rb which I don't have. Can't find it online for download. I guess, given that it's a ruby script, that it'll be the same for Mac or Windows.
    If you have this file, perhaps you'd be willing do do me a favour and email it to me?
    Actually, I just saw that we can do .txt uploads here so if somebody could change the extension from .rb to .txt it could be uploaded here if that's more convenient for you.
    Help on this will be greatly appreciated.
    Feb 2010
    119
    Re: Need sketchup.rb file for SketchUp v7
    I have v8, not sure if this will help you. Found this file in the tools folder. Changed the extension to txt like you asked.
    Apr 2009
    39
    Thanks bozidar22. It's got to be worth a try. However that script says it also needs langhandler.rb
    Sorry to be a pain but do you have that one too? Hopefully that's the last of it.
    Can't understand why I don't have them as part of my installation... but I don't!
    Feb 2010
    119
    If you need any more let me know
    Attached Files Attached Files
    Apr 2009
    39
    Many thanks bozidar22 but it turned out that the issue was with something else, not missing files:
    I'd seen info to the effect that the ruby script files needed to go into
    ~/Library/Application Support/Google Sketchup 7/SketchUp/Plugins
    So I found
    /Users/<my name>/Library/Application Support/Google Sketchup 7/SketchUp/Plugins
    and put them in there. It didn't work.
    After the second file you sent me didn't work I was scratching my head and realised that I had another plugin installed which, when I downloaded it again to check, was also ruby script... and that pligin was working... so where the hell had I installed the file?
    After much searching I found it in:
    I put the new plugin in there... and it worked. Doh!
    Thanks again for your help. While the files you gave me didn't actually solve my problem, without your help I would have continued to think that was the problem and would never have got to the bottom of this. I now have a working curve stitcher tool. Yay!
  1. Sketchup pro to mastercam x file transfer?
    By Sketchup fan in forum Uncategorised CAD Discussion
    Last Post: 06-01-2014, 03:30 PM
  2. Sketchup to CNC dxf file guide
    By piratebrian in forum Uncategorised CAD Discussion
    Last Post: 05-31-2014, 05:30 PM
  3. Is anyone using SketchUp Pro?
    By Brian@Premier in forum Uncategorised CAM Discussion
    Last Post: 02-06-2014, 05:16 PM
  4. Sketchup
    By lgalla in forum Uncategorised CAD Discussion
    Last Post: 09-29-2012, 01:20 AM
  5. Sketchup file of CRP 4x4
    By vtx1029 in forum DIY CNC Router Table Machines
    Last Post: 12-31-2011, 11:07 PM
