587,603 active members*
3,756 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Open Source PM-30MV-L CNC Conversion
Page 2 of 2 12
Results 21 to 36 of 36
  1. #21
    Oct 2013
    6
    Re: Open Source PM-30MV-L CNC Conversion
    Hi Gentlemen,
    I'm a newbe here and I'm following this with great interest. I'm hoping to build one of these early next year and the info here is awesome. But I do have a question:
    It seems everyone mounts the Y axis motors in the front. I'm sure you all have good reasons for this, But I'm thinking I would prefer to put mine in the back. Would you
    all please comment on the feasibility of mounting the Y axis motor in the rear.
    Thanks,
    Maddawg
  2. #22
    Dec 2013
    14
    You can do it. The ballscrew will need to be longer. Be careful of the gas strut since it is mounted in the base of the column.
  3. #23
    Oct 2004
    298
    The main reason I didn't do this was because the castings aren't terribly accurate. There's not a good flat part to mount to (the casting on the back of the column isn't really flat), so I'd probably need to mill it down to get a flat surface. Also, there's not a good place to have the ballscrew run through, so you'd need to drill a hole or mill that out as well. It was a lot more work than just sticking it in the front.
    YouTube Channel: https://www.youtube.com/c/RobertCowanDIY
  4. #24
    May 2013
    455
    I also think that the Z column shock is in the way as well. I remember I really wanted to do a back mount as well, but I came to the conclusion I couldn't, and I think it was because f the shock.
  5. #25
    May 2008
    1185
    I will be selling my Weiss 30 soon if anyone is looking. It has a CNC kit on it but I wont be selling a controller.
    I have just received a 4th mill and i just don't have the room for the 30. It looks like new with only a few hours of CNC use on it. Send me a PM.
    I'm in Arizona.
    Dave
    youtube videos of the G0704 under the name arizonavideo99
  6. #26
    Jan 2013
    20
    Nice build, very clean work and great photos. Looking forward to the next chapter
  7. #27
    Oct 2004
    298
    thanks, I really need to do a better job of updating my blog and videos, but I've just been busy. the mill is working and I've been using it, I just haven't gotten around to documenting everything :-/
  8. #28
    Jul 2013
    1
    Very nice build and blog!
    I got a WMD30LV about a year ago and i've been thinking about converting it ever since. Is it possible to have the cad-files of the original mill? It would be a really big help.
  9. #29
    Oct 2004
    298
    Quote Originally Posted by Mabel View Post
    Sure, send me a PM with your email and I can send you the zip file.
  10. #30
    Aug 2005
    1102
    Quote Originally Posted by cowanrg View Post
    It's been awhile! I've accomplished a lot. I have the mill fully running, I just need to add some limit switches and such. I'm cleaning up the model right now, but almost everything is modeled. Here is the X bearing block assembly:
    Attachment 245834
    Great job, Really nice documentation.
    I may have missed something, but, in your X bearing block, what is stopping the whole leadscrew with bearings attached from sliding out the end of the bearing block towards the motor?
    Hopefully your not relying on the stepper motor to stop it. Stepper motors have a spring thrust washer on the end and allow some movement for expansion. Also the stepper bearings are not designed to take axial force.
    The other end of the leadscrew needs to float in a bearing to allow for leadscrew thermal expansion.
    Cheers,
    Peter
    Homann Designs - http://www.homanndesigns.com/store
  11. #31
    Aug 2005
    1102
    OK, I worked it out. The bearing block is bored from either side.
    Cheers,
    Peter
  12. #32
    Oct 2004
    298
    Hello everyone, I'm bringing back an old thread :-)
    Since I now have a Tormach 440, I am putting the PM30 up for sale. For right now, this is a local cash sale only, I'm not interested in shipping it. However, if you can arrange for it to be picked up and all that, I could entertain it.
    I'm in the Denver area and here's the craiglist ad:
    Precision Matthews PM-30 CNC Milling Machine
    Let me know if you're interested or have any questions!
  13. #33
    Feb 2018
    8
    cowanrg
    I realize this is a long dead thread, but just found it and was excited to rea your blog and see the pictures since I will be tackling a PM-30 CNC as well...but its gone now. Do you have this posted anywhere else for me to checkout and help me through it and more importantly get the right stuff the first time.
  14. #34
    Nov 2016
    3
    I'd like the information also.
  15. #35
    May 2008
    1185
    One thing I see with the drawings here is they are of the older Weiss30\ PM-30. The current mill has a different table and Y mount and slide. The Z looks to be unchanged.
  16. #36
    Oct 2004
    298
    Hello everyone, I dropped this project and got a Tormach 440 and haven't looked back, but here is a link to the assembly of the machine, or at least the machine I got:
    https://drive.google.com/open?id=0B3...zhRUWdnblQ4SWM
Page 2 of 2 12
  1. PM-30MV-L CNC conversion
    By AVRnj in forum Benchtop Machines
    Last Post: 05-03-2015, 12:31 PM
  2. PM-30MV or G0704 for CNC Conversion
    By cowanrg in forum Benchtop Machines
    Last Post: 02-19-2014, 03:27 AM
  3. PM-30MV CNC Conversion
    By comtech in forum Benchtop Machines
    Last Post: 02-14-2013, 08:13 PM
  4. Open Rail - open source linear bearing system
    By milatary56 in forum T-Slot CNC building
    Last Post: 06-09-2012, 02:07 PM
  5. Open Source X2 CNC Conversion
    By ignatz in forum Open Source CNC Machine Designs
    Last Post: 03-12-2006, 11:40 PM
