587,431 active members*
3,099 visitors online*
Results 1 to 2 of 2
    Jul 2014
    6
    Question Need a new stepper
    Hi people I need help. Our rotary cnc machines nema 34 stepper motor is failing and needs replacing. I can't find an exact spec match. I need to know a few things..... If I can't find the exact spec that perameters need to be the same and what perameters can change in value slightly e.i voltage,current, step angle, torque etc. I would also be very greatful If anyone could find an eBay exact or equivalent that would do the job.no have attached all the info I know on the motor in the form of a image....
    please please help it's a breakdown situation
    thanks in advance
    brad griffiths
    May 2005
    1397
    Re: Need a new stepper
    You might find a motor that is close in spec on this page:
    techref.massmind.org/techref/io/stepper/linistep/motors.htm
    I've been trying to build a database of commonly used, good motors. Please consider adding motors you find.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. Live stepper driving a dummy stepper, via timing belt, on dual ball-screw X axis?
    By Rees Guitars in forum DIY CNC Router Table Machines
    Last Post: 02-10-2014, 05:12 AM
  2. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  3. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  4. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  5. Wanted DIY stepper driver circuit for 6 wire stepper motors
    By Colin300 in forum Australia, New Zealand Club House
    Last Post: 09-21-2007, 03:20 AM
